The last time my Inspire HR successfully synced was 11 November 2020, I stopped using it for a while and since reusing it have failed to sync. I have tried rebooting the device, clearing all the data, uninstalling the app and re-installing as well as turning on/off bluetooth.
Seems to be a common issue.
06:24
06:00
01-06-2021
06:24
06:00
@axgriffi @Jenbatt It's good that the community is growing!
Let me help you with this and thank you for troubleshooting this issue. I suggest your try clearing the link between your phones and your trackers (these instructions includes some steps that you have already tried):
Let me know how it goes.
Best AnswerUnfortunately, I like all the others have followed everything. Nothing seems to be working besides giving headaches. 😔
01-11-2021
10:28
05:59
01-11-2021
10:28
05:59
@LaceDragonfly @Ladybirdintheuk It's nice to have you on board!
Thank you for troubleshooting this issue. I have created tickets for both of you so our Support team can further assist you via email.
@axgriffi happy to hear that your issue was resolved and thank you for sharing what you did to correct this.
Keep me posted.
Best AnswerI am having the same issue with not being able to sync my device with the app, all of a sudden. So my Inspire HR is now useless. Please fix this issue Fitbit! Seems like a lot of problems are related to Fitbit updates.
I have the same problem. Inspire hr has worked a year nicely, now it doesn't sync at all. Contacted support and he said that i have wrong phone (oukitel wp6, android) but it is odd that the problem is my phone when everything was ok 2 days a go and whole year before that. I have tried everything (by myself and with support) and still nothing. Now my device has wrong time, i can't put alarms, all settings are wrong, so hole device is useless. I'm so annoyed and there is nothing i can do. Support just cut me off when he said all is done what is possible to do, so i only thing there is to do is a buy now phone or throw my inspire hr to the trash. Great support i say.. 😕
Same problem. Time off by half an hour. Bluetooth keeps dropping connection. Have a much newer iPhone now. Why is this a problem?
