01-07-2020 03:35
01-07-2020 03:35
I was sat down,put my watch on,everything synched to 0 for the new day,yet it showed I had burned 243 calories and taken 31 steps!! Can anyone help on this question.
Thanks
Best Answer01-07-2020 05:15
01-07-2020 05:15
Happy the BMR explanation helped.
As to the 31 steps... I could see it picking up a few steps from the motion of picking it up and putting it on but 31 seems a bit high for that.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
Best Answer01-07-2020 03:49
01-07-2020 03:49
Fitbit resets the calories at midnight. It then begins to estimate your calorie expenditure based on your Base Metabolic Rate (BMR). BMR uses your stats (sex, age, height, weight...) to estimate calorie usage. It does this even if you don't wear the device as this is the baseline calorie usage even if you are passed out on the couch. You can check the accuracy of the BMR by going to various BMR estimation sites on the web. Any activity calories then get added on top of the BMR.
Best Answer01-07-2020 04:00
01-07-2020 04:00
Best Answer01-07-2020 04:01
01-07-2020 04:01
Thanks for your detailed explanation,very helpful.
PLEASE can you tell me why it clocked up the 31 steps without me having the watch on. Thanks.
01-07-2020 05:15
