03-22-2019 12:21 - edited 04-09-2019 11:48
Fitbit update: 4/9/19 Our engineers have added the Stats Heavy and Valerie clockfaces back into the gallery. Feel free to re-install them if you had recently removed them due to battery concerns.
Our team was recently made aware of an issue which may be affecting some users battery life while using certain clockfaces on Inspire and Inspire HR. We are currently looking into this and hope to have a fix identified soon.
In the meantime, I recommend switching to one of these three clockfaces: Simple Stats, Shifted, or Analog. After some testing, our team has determined that switching to the above clockfaces should help alleviate potential battery drain.
If you are experiencing short battery life after switching to one of the clockfaces above, I also recommend performing a quick restart and following the troubleshoots listed in this article.
As always, I will be sure to keep you all in the loop as more information becomes available. Feel free to let me know if you have any additional insights or questions. Thanks again!
Want to get more deep sleep? Join the discussion on our Sleep better forum.
04-10-2019
19:11
17:57
RicardoFitbit
04-10-2019
19:11
17:57
RicardoFitbit
Hi Matt,
No good news. Because I liked it when I first got my Inspire, I switched to the Valerie clock face. I noticed my batter draining even faster than usual so I tried Stats Heavy - same problem. I was down to 10% and it hadn't even been 48 hours - that's faster than usual.
Something is wrong and it's unfortunate that so many people are having problems.
After two calls to customer service, I am being sent a new unit, which I appreciate. I truly hope I have the same experience as others - that the replacement works much, much better. I'd like to get back to wearing and enjoying my FitBit, not constantly checking to see if I have enough battery left to tally my steps.
Moderator edit: format
04-10-2019 19:36
04-10-2019 19:36
Even after the clock face fixed. My battery is still drained after 2 days. I charged it fully on Tuesday and now I’m at 38% on wed evening. Probably could last another day but still.. how can I fix this. And I haven’t changed my clock face yet. I’m on the one that you said to go back on while they were fixing it..
04-10-2019
21:50
11:10
JuanJoFitbit
04-10-2019
21:50
11:10
JuanJoFitbit
Some additional data points:
I let my Inspire HR die (no smiley face when pushing button, completely dead) then charged it overnight.
Battery lasts about 4 hours.
I noticed that the green LED in the back is never shutting off.
So I charged it again overnight and turned off HR. The green LED is not on at 50% duty cycle at what looks like 1 second per cycle. Took the device off my wrist and the green LED never turned off completely, for approximately 4 hours at which point the device was dead again.
I will call Fitbit tomorrow and request a replacement device.
At this point, it is not even useful as a paperweight because it is not heavy enough.
P.S. Tried restarting via instructions first, no luck. I then tried restoring the device to factory setting and repairing, again no luck.
Moderator edit: merged reply
04-11-2019 03:45
04-11-2019 03:45
Everyone is just reporting "bad battery life" I know it's upsetting, but its not helpful, try different clock-faces each day and if the battery depletion is the same with each face, you can establish it's not the clock face doing it.
Mention what phone your Fitbit is connected to, maybe that will help establish whether more people are having a problem connected with an Android phone & App vs iOS.
Personally, I think there are just some bad batteries out there, but if you want the actual issue fixed (or just established), give them some actual details to work with 🙂
04-11-2019
12:38
17:58
RicardoFitbit
04-11-2019
12:38
17:58
RicardoFitbit
Here's some details for them. These devices should be able to go a week without charging.
Why on earth do they think people want to recharge every couple of days? That is absurd .
A week. Start working on it.
When you get this part right, Then, I might consider buying another one.
04-11-2019 13:57
04-11-2019 13:57
...it says "up to 5" days on the box... 🙄
04-11-2019 14:19
04-11-2019 14:19
🙄 and you’ve never made a typo. Regardless of it lasting Up to 5 days, it’s still not living up to its potential.
04-11-2019 14:26
04-11-2019 14:26
It’s a box of lies 😂
04-11-2019 15:02
04-11-2019 15:02
Yes, that would be helpful. I did follow the suggestions in the links you sent with no luck. Now, the Inspire does not reliably connect to my phone via Bluetooth. It is not working well at all.
Thank you for your help.
04-12-2019 04:04
04-12-2019 04:04
I just put valarie clock face on yesterday morning after being charged all night the night before. I’m already down to 38% this morning. It’s even worse now. May need to change back to the other clock face that gives me 2 full days.. 😪☹️
04-12-2019 04:33
04-12-2019 04:33
I just got it a week ago & my battery died won't hold a charge at all. Can we swim with it or not?
04-12-2019
09:05
17:58
RicardoFitbit
04-12-2019
09:05
17:58
RicardoFitbit
I just bought the inspire, they don’t sell insurance plan at Best Buy And now it doesn’t charge. What the heck
04-12-2019 09:12
04-12-2019 09:12
Call customer support. I called yester and they are working with me to see if we I can qualify as a warranty issue.
04-12-2019
09:23
12:34
AndreaFitbit
04-12-2019
09:23
12:34
AndreaFitbit
Lots of luck—My battery is bad, my watch never shows how much I sleep, and some days my alarm works and some days it doesn't. Woke up 15 min late today….And yet I get zero useful help from. Wasted money and dangerous if relying on this watch.
Moderator edit: format.
04-12-2019 09:37
04-12-2019 09:37
I also called Customer Support and they were very helpful. They verified that my battery life was consistently under 48 hours. They did some things and asked me to call back if there was no improvement. There wasn't any, I called back and they sent me a new device. I just booted it up this morning and so far, it seems like the battery isn't draining as quickly. I'll report back in two days to see if there is a significant improvement. If there is, that would suggest a bad batch of InspireHR devices.
04-12-2019 09:42
04-12-2019 09:42
04-12-2019 09:45
04-12-2019 09:45
04-12-2019 16:50
04-12-2019 16:50
@MattFitbit , a few days after switching to the newly-reinstated Heavy Stats clock face, my battery usage has changed very little, if at all. I’m happy to report that I’m on track to still get over 5 days on a charge. The last cycle, (which included one day of using the Heavy Stats face), I still had 20% charge left after 7 full days.
04-12-2019 18:32
04-12-2019 18:32
My battery life is 30-36 hours.I have tried restarting multiple times and the troubleshooting tips and I refuse to turn off functionality that I had with the Alta HR. What’s the point of having an Inspire HR if you can only use it as a watch to save the battery. The screen is also too sensitive and I find that I’m often “exercising”, usually swimming, if I graze it as I go about my day. This device was a disappointing waste of money and I’ll be returning it.
04-12-2019 19:31
04-12-2019 19:31
