Battery was holding charge for days. After a recent update it now drains daily. I also noticed since the update it vibrates and congratulates me every time I take 10 steps. I am sure that’s what is draining the battery. How do I stop that? And how do I increase battery life?
08-27-2020
10:05
07:50
08-27-2020
10:05
07:50
@Lynnr1231 It's great to see you in the Community!
Let me help you with your Inspire's battery draining quickly. What are you seeing when you say it congratulates you for every 10 steps walked? Could you share a picture of this? I suggest you start by restarting your tracker. After this try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. You can follow these instructions to help improve the battery life.
I look forward to your reply.
08-27-2020
10:05
07:50
08-27-2020
10:05
07:50
@Lynnr1231 thank you for the update.
Really happy to hear that you were able to fix the issue and thank you so much for sharing what you did to fix this as it may help other members in the same situation.
Happy stepping and stay safe!
