I woke up one morning to find the case where the band joins was broken. A tiny piece of plastic has snapped out of it making the band unable to stay in place therefore, unusable. Is there anything that can be done?
Hi @TashaM6 if it's not under warranty, there isn't much you can do. However, Fitbit made a clip for the Inspire and you could use it that way and not worry about using a band.
02-22-2021
11:04
10:24
02-22-2021
11:04
10:24
@TashaM6 It's great to have you here!
Let me help you with this. If your tracker is under warranty I suggest you contact our Support team. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
@Odyssey13 thank you for your help here.
Hope this helps.
