09-09-2020
08:51
11:49
AlvaroFitbit
09-09-2020
08:51
11:49
AlvaroFitbit
Dear Sir/Madam,
I bought a Fitbit Inspire about 1 week ago, and I charged it up and followed all the steps in order to get it started.
Unfortunately it doesn't want to work and I am confused as to why its not working?
Can you please tell me if I'm doing something wrong and how to fix it?
If not I'd like a replacement sent to my address as I was looking forward to using it.
Moderator Edit: Personal info removed
Best AnswerHi @Graememazur please return and edit your post as you have personal information in there. These are the community forums, quite public and not customer support. I'll post the support contact information, but please remove your information as anyone coming to the forums can see it.
Fitbit customer support is doing their best, but right now be prepared for longer wait times. Please be patient. Support is limited by the number of representatives available at a given time and the hours of operation. Chat lines are open when they have live help.
UK: call 0800 069 8505
Other contact options
https://myhelp.fitbit.com/s/support?language=en_US
Best AnswerI can charge the Inpire fitbit but will not let me go any further it will either just have a line nothing else so I let it charge until the smile face again then it goes into www.fitbit.setup nothing else
12:28
06:11
09-09-2020
12:28
06:11
@Graememazur @Dianendfan It's great to see you in the Community!
Let me help you with your Inspire not working. @Graememazur have you tried any troubleshoots? Could you add more information about the issue your Inspire is having? Is it not lighting up at all? Could you see if it charges? Try restarting your tracker by following these instructions.
@Dianendfan since your tracker is showing the setup page I suggest you retry setting it up. If it doesn't respond to this then remove it from your account (tap the top left button and then the tracker button and finally the trashcan button at the top right corner to remove it), after this retry the setup. You could also try restarting the tracker following the instructions above.
You could also reach out to our Support team like @Odyssey13 suggested.
I look forward to your reply.
