Inspire wristband hard to clip
ANSWERED
I just got my Inspire, got it set up and then tried to put it on. How do you put this thing on? It takes too much pressure to put the prong into the little hole. I've ended up breaking a couple of nails and just looping and locking it around my bra strap (have a clip on order). Seriously how does one do this with one hand?  The band is too stiff and just rolls around while I was attempting to secure it to my wrist.
22 REPLIES 22
I clip mine, put hand lotion on the left hand and wrist and it slips right on. I used to tug and pull. This is easy.
have been trying to close the strap for a few hours now.
It's a pieceofcrap. don't buy!
Clasp it, rub hand lotion on hand and wrist and see if it won't slide on. Works for me and I have a wide hand.
Sent from Yahoo Mail on Android
