09-18-2019
		15:27
		12:56
			AndreaFitbit
		09-18-2019
		15:27
		12:56
			AndreaFitbit
When My versa 2 just arrived and I used Alexa and it worked for a few times that I tried it. Later on I tried using it again l and now it doesn’t recognize my voice no matter what I say constantly says sorry please try again.
I’ve also tried shutting it off and turning it on again with no luck
is anyone else having the same problem or know a fix?
12-15-2019 08:27
12-15-2019 08:27
If you Google fitbit customer service, their 800 number pops up. I just got off the phone with another issue and it's resolved. As for Alexa, I had to be sure both phone and watch were on 2g. Phone was on 5g. When I changed that and restarted things, it finally worked. But if not, I'd call them. Very helpful to talk to a person.
09-18-2019 18:12
09-18-2019 18:12
Your app needs to be running in the back ground.. sync your device I don't close the app, then try using Alexa
 Best Answer09-18-2019 18:16
09-18-2019 18:16
 Best Answer09-18-2019 18:19
09-18-2019 18:19
Check language settings, that's my guess.
 Best Answer09-18-2019 22:12
09-18-2019 22:12
I cannot connect my Amazon account, this a. Half baked product
09-19-2019 05:10
09-19-2019 05:10
Yeah I initially thought that was the case too but it’s set to
english
 Best Answer10-04-2019 03:46
10-04-2019 03:46
Paul,
I have having the exact same issues and have tried the same, still isn't worling for me either
10-04-2019 06:35
                              10-04-2019 06:35
@Paulbabchuk, have you tried connecting your phone to a different WiFi network or even cellular data? I had a similar issue and it turned out it was an issue with my home broadband (maybe a dns issue?), rebooting my router/modem did the trick. Its worth trying if you haven't already done so.
 Best Answer10-05-2019 14:23
10-05-2019 14:23
I'm having exactly the same problem. Have just received the versa 2, setup and update went through with no problem, but alexa doesn't seem to respond at all. Have tried resetting to factory defaults, tried on both wifi and 4g connection, tested on another amazon account and still no joy. 😞
 Best Answer10-06-2019 09:40
10-06-2019 09:40
Thanks for the tip but after trying it I am still having the same problem.
 Best Answer10-08-2019 05:20
10-08-2019 05:20
I am having the exact same issue. It worked when I first got it and now a week later it is saying that it can not understand what I'm saying and to please try again. I have tried it on 2 different wifi networks and mobile data, double checked all of my settings to make sure bluetooth, alexa, english, and the microphone are turned on and also reset the app and the watch. I don't know what else to do. I got this watch because I was excited to be able to talk to alexa on my wrist. It's really frustrating that it is not working.
10-08-2019 06:24
10-08-2019 06:24
10-08-2019 06:42
10-08-2019 06:42
I have tried talking loudly right next to it, even yelling one of the times just to see if the microphone was having a hard time picking it up. It registers that it is hearing me but then it says it was not able to understand what I am saying. And what I really don't understand is why it up and quit out of the blue when it had been working just fine for the first week of having it.
10-08-2019 06:45
10-08-2019 06:45
 Best Answer10-08-2019 06:47
10-08-2019 06:47
Ok, so tried the following:
- Removed Versa2 from account and re-added - Still no joy
- Removed Versa2 from account, and added it to my partners account on a different phone - Still not working.
- Removed it from that phone, removed Fitbit App from my phone, re-installed Fitbit App on my phone which now has a Fitbit pedometer service running (which wasn't there before), and added Versa2 back on - Success. Alexa working as expected.
I'm running Android 9 on a Galaxy S8+ btw.
10-08-2019 07:13
10-08-2019 07:13
I just tried the last one that you wrote and it's still not working..... 😟
10-08-2019 07:26
10-08-2019 07:26
It is finally working! I had to go in to the app to my versa. Then I had to log out of my amazon account and log back in. I dont understand why it didn't work when I reset the watch and had to log back in as well. But I'm just glad its working again. Thanks everyone for the helpful tips!
10-27-2019 11:43
10-27-2019 11:43
Yes having exactly the same problem..worked a couple of times now zilch!!😡
10-27-2019 11:46
10-27-2019 11:46
It shouldn't be this complex to use or set up..no warning it's not going to work without changing things..
10-28-2019 11:20
10-28-2019 11:20
I've tried all of the recommendations mentioned of this thread, and it still isnt working. 😞
Any other suggestions?
