01-30-2022
07:51
20:34
01-30-2022
07:51
20:34
After a full charge, the versa 3 lasts exactly 12.5 hrs before I got a low battery warning. I have no alarms, and it was set to "do not disturb", with the brightness all the way down.
02-24-2022 20:38
02-24-2022 20:38
So I reported it to fitbit, who really dragged out the "fixes" with: have you tried turning it off, and then back on, and then the watch wouldn't last more than a few minutes. It turns off as soon as you unplug it, and now she's out of warranty. Nearly $300 for a watch that i barely used to last just over a year? And they just offer me a coupon for a new one? No thanks. Won't be buying a fitbit again.
01-30-2022 20:45
01-30-2022 20:45
HI @Lyndsay.duff - new features, particularly Snore detection can affect battery usage, carefully check each of the issues in How to resolve the Major issues causing short battery life.
Best Answer01-30-2022 21:19
01-30-2022 21:19
Hi, so I don't have snore detection, my screen is already set to dim, I have no push notifications and its set to do not disturb. I don't use the GPS, and have never played music on this watch. I took it off charge at 4pm, and at midnight, I'm already at 50%. As of now I'm only using this to check the time for half a day.
22:19
08:50
01-30-2022
22:19
08:50
@Lyndsay.duff - if you have tried all the option in the listed link [including restarting both the watch and phone and running with the Bluetooth off] the next step is to contact Fitbit Support directly. They may be able to help you with more deeper troubsleshooting
Also reachable via the Fitbit App, click profile photo, Help & Support, Contact Customer Support.
If it is still under warranty and found faulty it may be better to take it to the shop for a new replacement, rather than accepting a refurbished replacement from Fitbit and dealing with sometimes drawn out return and shipping issues.
Best Answer02-24-2022 20:38
02-24-2022 20:38
03-02-2022 01:36
03-02-2022 01:36
Same problem with me, fully charge and finished battery in 10hour, i have try no sync and off every anything also faster drain battery.😒
03-02-2022 04:42
03-02-2022 04:42
