01-21-2019
08:56
15:15
DavideFitbit
01-21-2019
08:56
15:15
DavideFitbit
I have had my Versa tracker since Christmas. I have worn it constantly since then. At first, I was taking it off to charge every other night and sometimes charging it while I was In the shower. The battery life was great, lasting 3-4 days at a time until about a week ago. It shows that its 100% charged when I remove it from the charger around 5:00 am, but then the battery is under 50% by noon and totally dead by 4:00 or 5:00 pm, even after charging for 8+ hours the night before. I have uninstalled everything on my tracker that can be uninstalled, left it on charge for 48 hours, and cleaned the contact points on my charger and tracker. Is there anything else I can do to fix this problem, or should I contact Fitbit for a solution? I love my tracker, but it's of no use if it wont stay charged!
Moderator edit: format
01-21-2019 09:07
01-21-2019 09:07
Hi, I would advice you to contact Customer Support, seems a hardware issue.
01-21-2019 09:07
01-21-2019 09:07
01-21-2019 10:08
01-21-2019 10:08
I contacted customer support. I have to do a battery drain test and then contact support again with the results. Thank you!
01-21-2019 17:35
01-21-2019 17:35
01-21-2019 17:43
01-21-2019 17:43
Hi Maria, contact again Customer Support, cause this is a hardware issue. You did what they asked and it does not work. Good luck!!!!
01-21-2019 18:20
01-21-2019 18:20
Wow, I had to do a battery drain test and mine lasted 5 hours with notifications and heart rate monitor turned off. It takes almost as long to charge the thing as it does for it to drain. I would love to know just how many people are having this problem.
01-24-2019 20:00
01-24-2019 20:00
I have had my versa for about 8 months. Great battery life which got even better with the recent update allowing up to 5 days. As of 1/21 I am down to less than 12 hours with no change to setup or usage. Today it died by 4pm after being full at 7am. Gone from great to useless in no time.....
03-13-2019 06:12
03-13-2019 06:12
I bought my versa last week by online at JB HiFi online in australia
then problems starts twice now when i pit on charging around half an hours saying Not Charging. Not enough power detected from this source!
Also battery life only less than 10hours dropping 20% so quick red battery
Im confused what happen now as my versa still brand new only less than 10 days, do you think could be failed product from factory? could anyone help me please
03-13-2019
10:37
08:56
03-13-2019
10:37
08:56
@vhia77 Welcome! It's great to see you around! Sorry to hear that your Versa's battery is draining quickly. Try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves. You can find additional instructions here.
Let me know how it goes.
03-13-2019 14:49
03-13-2019 14:49
04-09-2019 18:37
04-09-2019 18:37
Thanks for the suggestion. I now have 2 watches both have the same problem the fitbit Blaze and the Versa. I will try what you suggested. I really appreciate it. Thank you!
