Bluetooth sync
Wont pair with new galaxy s10
2 REPLIES 2
https://www.fitbit.com/devices
You proabably have an incompatible device. I recently discovered that my LG V35 is not a compatible device hence i shall ALWAYS have syncing issue. At least with samsung it looks like comaptability may become a reality as S9 is listed as a ok device. So u may only have to wait for an update.
@Napier33  are you in the process of setting up your Versa or Versa Light?
If so at what step of the setup process does the failure occur. Do you get any wore messages and what would they be?
If you're not setting up the tracker, what issue are you having?
