11-21-2019 04:19
11-21-2019 04:19
My Versa will not pair on Bluetooth
11-21-2019 07:12
11-21-2019 07:12
Hello @AM43 what type of error do you receive? Was the error "Rejected by Versa"?
A user is not able to pair through bluetooth but needs to do an Add Device through the Fitbit app.
Best Answer11-21-2019 07:18
11-21-2019 07:18
Thank you,
On ADDDEVICE it will locate Fitbit but will not pair.
Best Answer11-21-2019 08:20
11-21-2019 08:20
You don't care if it pairs to your phone yet.
The app needs to locate the tracker. The tracker displays a code that the user puts in the app.
The app then connects the tracker to the users account.
Then if the app needs the tracker paired to the phone, the app will ask for permission to pair the tracker.
Best Answer11-21-2019 08:36
11-21-2019 08:36
I'm having the same problem as the OP, trying to set up a new Versa 2, phone app detects Versa 2 almost immediately, but never connects and I never get the 4 digit number to enter into the app.
Best Answer11-21-2019 08:39
11-21-2019 08:40
11-21-2019 08:40
This is as far as I get trying to set it up
