05-08-2019
16:08
09:10
JuanJoFitbit
05-08-2019
16:08
09:10
JuanJoFitbit
The 2 buttons on the right side of my versa do not work. I can’t press them at all no matter how hard I try. They won’t budge. How can I fix this issue?
Hi, the two buttons on the right side act like a shorcut. If you press the upper right button slighlty, it will open the app that's on the first page on the left side of your apps page, in my case this is the weather app. When you press the lower right button slightly, it will start the app that's on the lower left side of the first page of your apps, in my case Philips Hue. If the right buttons do not act in this way, open one of these apps and assign them to one of these buttons. F.i. open the weather app and press the upper right button, etc. Works for me always. See also this article about how to navigate my Fitbit's screen. Press the link and scroll down to "Use the buttons"
05-09-2019
09:09
08:56
05-09-2019
09:09
08:56
@Cristal157 Welcome to our Fitbit Community! I'm happy to assist you with your Fitbit Versa since the buttons on the right side are not working properly.
I'd just like to know if the issue persists or if it got resolved after following the tips that shared @SunsetRunner. In addition, please try to clean around the buttons with a toothpick in order to remove any dust that may be affecting the buttons.
Looking forward to your response! ![]()
This happened on my fitbit Versa also and the above solution did not work. Any other suggestions? I was in the Exercise - Swim app when I noticed this and now I cannot close the app.
08:22
08:54
01-15-2020
08:22
08:54
@JLS819, I'm sorry for the late response. However, thank you for joining us in this thread.
Since the buttons of your Fitbit Versa are still not working after trying the recommended troubleshooting steps, let me go ahead and forward your case to our Support team so they can review it and assist you accordingly. You will receive an email from them soon.
I'll be around if any question arises.
Best AnswerI have the same problem, but instead ALL my buttons won't work unless I restart my watch. This happens after my watch acts strangely as I described in my post: https://community.fitbit.com/t5/Versa-Smartwatches/Versa-Acting-Strange/m-p/4118446#M169365
Best AnswerI'm having the same problem my phone can't find my versa and I need to reset but can't use the buttons on the right side either they just don't move did you ever find a solution? I love doing the challenges with friends it really helps to get me moving but I can't use them without my versa syncing with the app. 😥
11:03
08:52
03-22-2021
11:03
08:52
Hi @Heg1985, thank you for joining our Fitbit Community and this thread. Since you mentioned that the buttons of your Fitbit Versa are not working properly, please use a toothpick around the buttons in order to remove any dust or moisture. After this, check out if the buttons work properly.
Keep me posted on the outcome.
