04-24-2019 08:58
04-24-2019 08:58
The Huawei P20 Pro is listed as compatible with Fitbit devices however I can't get it to pair successfully. The devices talk to each other, I get the code and enter it but then it doesn't show as a device in the Fitbit app. My Charge 2 pairs with no problems. Help!
04-24-2019 10:20
04-24-2019 10:20
Hi, maybe this guide I wrote when the new Firmware version was released and caused a lot of problems. You can use this also now cause when setting up your Versa, you will also get the latest firmware version. Main difference is that is uses WiFi to setup your Versa instead of BT: https://community.fitbit.com/t5/Versa-Versa-Lite/Hassle-free-guide-to-update-your-Versa-s-firmware/t.... Hope this helps.
Best Answer04-24-2019 11:01
04-24-2019 11:01
Thank you, unfortunately it hasn't solved my issue 😞
