06-02-2020 12:12
06-02-2020 12:12
I bought the versa 2 on Thursday but it will only allow me to reject calls. Friends of mine with the versa 2 longer than this can answer calls. How can i solve the problem?
06-02-2020 12:28
06-02-2020 12:28
Hello @Órla when the call comes in, at least with android phones, you should have the option to reject, answer, or send a quick response.
How to fix it, I'm not sure.
My thought would be to try setting the Versa 2 up as a replacement device.
Best Answer06-02-2020 12:32
06-02-2020 12:32
Yeah I have a Samsung so I thought it should work...
I don't get what you mean, the versa is already set in the app?
