04-23-2018 02:54
04-23-2018 02:54
Hi. I've read about compatibility issues with Huawei devices, including the P20.
However, I found this video in YouTube of a Versa being set up in a Huawei P20/ P20 Pro?
Sine I'd like to get this combination, I was wondering if anyone knows of any problems or someone else that done this set up successfully.
Thanks
https://www.youtube.com/watch?v=IEQYClAxFfE&list=WL&index=304&t=420s
01-04-2019 06:31
01-04-2019 06:31
Thank u but its just will not budge from the connecting screen xx
01-04-2019 06:33
01-04-2019 06:33
01-04-2019 06:34
01-04-2019 06:34
Thank you though xx
01-11-2019 14:18
01-11-2019 14:18
Has anyone tried this now the software on the P20 Pro has been updated to Android 9? You'd hope there would be some kind of fix by now.
02-14-2019 14:17
02-14-2019 14:17
Hi, I wanted to know how is the situation know?
I have a huawei p20 pro and really want to buy it but not if it doesnt work...
02-14-2019 14:30
02-14-2019 14:30
02-14-2019 14:39
02-14-2019 14:39
Hi!
I wander if your Huawei p20 pro is working fine with versa!?
I want to buy it but I'm scared to spend my money on something it doesn't work properly
02-14-2019 14:41
02-14-2019 14:41
The versa does work with the P20 all you have to do is go the battery settings on your phone and change the settings to manage manually on the Fitbit. They do work perfectly together
02-14-2019 14:47
02-14-2019 14:47
02-14-2019 14:49
02-14-2019 14:49
Weaven with the p20 pro??
02-14-2019 14:54
02-14-2019 14:54
Thanks for that Nitae Mine is a P20 lite not a pro. Just looking at battery settings. They are still to to manual. However under the battery manage batch options, 3 boxes are ticked (auto launch, secondary launch, run in background). Might this be the problem preventing sync? Or perhaps my Pro Lite version?
02-14-2019 14:56
02-14-2019 14:56
Sorry I don't know about the P20 pro.
02-14-2019 14:59
02-14-2019 14:59
Clarification - battery set to Manual 😊
02-14-2019 14:59
02-14-2019 14:59
I would try unticking one at a time. According to Fitbit, the versa is compatible with the Pro I don't know about the lite .I do know it has not been checked with the just P20 but after a lot of researching mine does now work and it is worth trying different ways of settings with the battery 😊
02-15-2019 06:16
02-15-2019 06:16
Hello!! I emailed fitbit and they confirmed me 100% that the versa is compatible with de Huawei p20 Pro!!
I ordered it and when I have it and tested it I can come here and confirm if it's doing well 🙂
02-28-2019 17:19
02-28-2019 17:19
Hello!
So about a week ago I received my fitbit Versa and I said here that I would give the news regarding compatibility and so. So far it works quite well !!
Whenever I open the app it connects, it takes a while but always connects! On the versa I get messages, calls, notifications (facebook, messenger, instagram, twitter ...) in the gym seems to detect my movements and efforts very well, showing later always in the application the results after conecting.
The only thing I'm still trying to figure out is the battery. As it is marketed to last 4 days, my lasts 3 in the following condition: the screen only turns on if you click the buttons, to save battery. If I go to gym today with 100% after exercise I should already have 70 or 60% battery. I do not listen to music with the watch, because I do not have headphones for that. So I expected it to last 4 days, on the third day it's already 20% low battery and i charge it...
But compatibility is 100% working well. That's why Huawei p20 pro is compatible, finally !!!
03-01-2019 14:18
03-01-2019 14:18
04-05-2019 03:17
04-05-2019 03:17
Can I ask were you given any indication when this might be done? If I knew this I wouldn't have purchased the fitbit as it's just a pain! Won't sync time is getting slower on the fb.....not tracking sleep ....won't connect...I'm tired of restarting all devices and still no improvement 😡
04-05-2019 04:59
04-05-2019 04:59
04-05-2019 08:24
04-05-2019 08:24
