02-19-2019
07:45
10:32
AlessFitbit
02-19-2019
07:45
10:32
AlessFitbit
How do I get my cozi calendar notification on my versa?
Moderator edit: title for clarity
03-03-2019 18:13
03-03-2019 18:13
@mh66 @SunsetRunner Ok, so I installed the Cozi calendar. It generates push notifications that can be seen in the phone Notification Center:
The Cozi calendar notifications can also be enabled in the Fitbit app:
I can confirm I am able to receive them on my Versa:
To enable the notifications, please open Fitbit mobile app, tap on the image of Versa, scroll down to Notifications and tap it. You should see this screen:
Now please tap App Notifications and scroll down until you see Cozi. Select it and tap the back arrow in the top left corner to go back. Sync.
02-19-2019 12:23
02-19-2019 12:23
@mh66 not sure what cozi calendar is but I am assuming you need to turn on the notifications for this app. Open Fitbit mobile app, tap on the Versa icon, scroll down to Notifications, tap it, and go to App Notifications. Enable it there. Sync.
02-20-2019 05:35
02-20-2019 05:35
Best Answer02-20-2019 11:25
02-20-2019 11:25
@mh66 naaaaah. I'm sure it's not that. Could you please describe where you're stuck? Were you able to locate the app notifications section?
03-01-2019 10:25
03-01-2019 10:25
@mh66 Did you manage to set up the notifications for your app?
03-01-2019 13:56
03-01-2019 13:56
Hi @mh66 . I googled Cozi Calendar. It is a third party app that is part of the Parents Network. It looks pretty good. Unfortunately, at this time, it does not work with Fitbit, as an app or with notifications. But other Fitbit users also like the Cozi Calendar. You can tap here to add your vote in the New Feature suggestion forum. This is where Fitbit gages interest and analyzes feasibility. Since this is a third party app, Cozi will have to work with Fitbit to make this happen. You should contact Cozi Calendar support and let them know what you want.
03-02-2019 09:04
03-02-2019 09:04
@SunsetRunner thanks for digging! 😄 Question, as an app for the phone, does it allow push notifications (notifications that show in your Status Bar)? If so, @mh66 should be able to set regular app notifications to show on his/her Versa. 😄
03-02-2019 16:13
03-02-2019 16:13
Good question, @Marrrmaduke.
03-03-2019 05:34
03-03-2019 05:34
@mh66. Did you see the questions from @Marrrmaduke ? Please let us know if we can help you in any other way. And if you find a way to make that calendar work with the Versa, please post it. It looks like a good calendar. Others may be interested.
03-03-2019 11:27
03-03-2019 11:27
I wrote to Cozi and also Versa, hopefully they pick it up love this calendar
03-03-2019 11:28
03-03-2019 18:13
03-03-2019 18:13
03-06-2019 11:18
03-06-2019 11:18
I am very excited for this but I still don't have it on my versa...I feel so stupid, I do see in on the app though
Best Answer03-06-2019 19:24
03-06-2019 19:24
@mh66 Could you please take a screenshot or a picture of what you can see in the fitbit app under the notifications?
03-07-2019 05:01 - edited 03-07-2019 05:03
So sorry for your frustration, @mh66 . From what @Marrrmaduke posted, it seems you will not see your Cozi calendar on your Versa. But you will see notifications from it.
To set this up, from the Fitbit app on your phone, tap Account > Versa > Notifications. From there, you should see Cozi as a notification option. (See @Marrrmaduke‘s photo.)
Cozi will then send notifications to the Versa. @Marrrmaduke, a question for you since you tested this. My Versa is linked to my iPhone calendar but only pushes out notifications for events that have alarms. Is this also true for Cozi calendar events?
03-07-2019 20:12
03-07-2019 20:12
@SunsetRunner Yes. The event has to have a notification/alarm set. Only this way it will appear in the Notification Bar. 🙂 @mh66 still should be able to see the app itself in the Notifications section of Versa in the Fitbit mobile app (as seen in the pic). I'm wondering if the OP is in the right Notifications if you know what I mean. Versa's notifications and not Fitbit app notifications...
03-12-2019 10:06
03-12-2019 10:07
03-12-2019 10:07
Let me know if you can see it please, if you cant tell already I am a bit illiterate when it comes to computers
Best Answer03-12-2019 13:42
03-12-2019 13:42
03-13-2019 07:21
03-13-2019 07:21
