03-09-2020 10:36
03-09-2020 10:36
Hello, I've set up Alexa in italian but, when I reply to a message, I need to select italian every time before speaking. Is there a way to set a different language by default for replying a message?
05-04-2020
07:15
09:21
05-04-2020
07:15
09:21
@viciovb Thanks for stopping by! Sorry for the delay in my reply.
Let me help you with your Alexa app losing the language settings. You should be able to save the language preferences in the settings area as stated here. I suggest you remove the Alexa app from your Versa 2, save and sync then reinstall it and configure it as you wish and see how it behaves.
Let me know how it goes.
05-04-2020 07:56
05-04-2020 07:56
Thank you but I've already solved my problem
