09-22-2019
11:29
13:27
SilviaFitbit
09-22-2019
11:29
13:27
SilviaFitbit
I use my blaze watch right now for my volume control during my yoga class I teach so I don't have to hold my phone on me and want to upgrade to the versa 2 but noticed they don't have volume buttons can someone tell me if the versa 2 has a volume control feature for music that is playing on a Bluetooth speaker ??
04-24-2020 10:39
04-24-2020 10:39
There are no volume controls in Spotify on Versa 2
Best Answer06-05-2020 12:04
06-05-2020 12:04
Thank you that, I’ve only just upgraded from versa to versa 2 but was worried that you couldn’t control the volume on the watch 👍👍
Best Answer06-05-2020 12:06
06-05-2020 12:06
I also had the Spotify screen with no volume controls but as above you need to pull the screen down and select music control
Best Answer06-06-2020 07:23
06-06-2020 07:23
06-06-2020 11:47
06-06-2020 11:47
Best Answer08-03-2020 02:50
08-03-2020 02:50
The +/- volume controls work intermittently while playing music files on the Versa 2 that is connected to my Apple AirPods. I've had the best luck with a pair of budget bluetooth air pod knockoffs. While using those, the audio loads at full volume at first (ouch!), but the +/- controls can be used to lower the volume as needed.
08-27-2020 00:51
08-27-2020 00:51
I can't control the volume with my fitbit versa2 on the music app
09-12-2020 21:10
09-12-2020 21:10
I am not able to use the music app, either. I see from the board that the issue with Air Pods (Apple) is well documented, but mine do not work, either. Is there a list of earbuds that work and ones that do not? It seems that as advanced as Fitbit is, this should be an issue that could be fixed with an update. It really makes the music feature unusable, which is the main reason I purchased the Versa 2. If it cannot be fixed, I may be returning them.
Best Answer09-17-2020 13:05
09-17-2020 13:05
The volume bottom doesn’t working on versa2
12-10-2020 12:36
12-10-2020 12:36
Has this not been solved yet? Do the volume controls for the Versa 2 still not work? I'm using Pandora with wireless headphones, and it's just too darned loud. I bought the Versa 2 in large part to have mobile music for running. If I cannot control the volume, it isn't doing that very, very basic requirement. Are we there yet with functional volume controls? I press the button, but nothing happens...
12-10-2020 13:33 - edited 12-11-2020 13:32
I'll add now that I've found a work-around. The Versa 2, to be sure, is not functioning properly, and Fitbit really ought to fix that. Very disappointed! That said, I have the Jaybird Vista headphones, and with their phone app, you can set the headphones to change their press functionality such that you can control volume directly with the headphones. So, it isn't excessively loud anymore and the music setup is useable. Again, Fitbit should have a volume button that *works* with all these headphones, but at least in the case of Jaybird Vista, there is an alternative method.
Best Answer12-01-2022 19:00
12-01-2022 19:00
So I see the buttons but whenever I press them it doesn't change the volume qhen I'm using deezer how do I fix it
