While I was changing the clock display, my Versa screen turned off and hasn't come back on. It was fully charged at the time, but the green lights doesn't turn on. I keep it on the charger, but nothing happens. I can't reboot it or anything.
Hi, are you also not able to restart your Versa with the two buttons method or even the three buttons method? Is your Versa still connected to the Fitbit app? If yes, install a Clock Face from Fitbit itself and see if that solves your problem, cause you possibly dowloaded a Third Party Clock Face that's not compatible with the new Firmware version. If none of the above works, contact Customer Support about your issue.
03-20-2019
08:18
10:17
03-20-2019
08:18
10:17
@Brian.G Welcome! It's great to see you around! Sorry to hear that your Versa screen isn't working and thank you for trying to troubleshoot the issue. Did you follow the suggestions @SunsetRunner shared with you? Is the issue still present on your device?
@SunsetRunner happy to hear that Support was able to replace your device and hope that you are already back on track.
Let me know how it goes.
