05-04-2018
00:17
07:51
RobertoME
05-04-2018
00:17
07:51
RobertoME
Hi There!
My versa loses connection with my phone (nexus 5x) during bike excercise and thus shows no route on the map. I know I have gps, because Strava app shows it right.
Is this a bug in the software from the Versa?
I tried to start an excercise from fitbit app, but only walk, run or hike does gps. (no bike. why not?!?) so i choose hike. now i have a hike excercise with hr and ps data. this this excercise shows after sync with strava in strava as hike. in strava i change hike in bike.
now i have bike excercise in strava with hr and gps. after a while just from magic, the ecercise in strava has been changed back into hike again with no hr data anymore.
I know that fitbit versa is not a swiss watch, but at least it should be working as advertised!
connected gps is not not working. People at Fitbit, can you fix this?
Moderator Edit: Updated Subject For Clarity.
11-03-2018 05:57
11-03-2018 05:57
All of us are having issues, not one or two. I have 9 tabs open on my browser from Fitbit forums, all users are having GPS issues. Just terrible.
11-03-2018 11:49
11-03-2018 11:49
Hello everyone, I hope you're doing well. ![]()
I appreciate your participation in the Forums and for sharing your experience with us. I sincerely apologize for the inconveniences you've experienced with your Versa and connected GPS and I understand you have already tried several troubleshooting steps so far. At this moment I would like to gather some information from you so our team can check this further, please reply with as much information as you can:
Thanks for your patience and understanding, I'll be waiting to hear from you.
Best Answer11-04-2018 01:11
11-04-2018 01:11
I am using an Android not an iPhone, I was bought the watch as a gift and they chose fitbit because it supposedly works well with Android.
The App version I have is 32.32.10.15.
The other code is version 2.81 (20213328).
My watch has completely stopped linking to my phone now, I can't review the stats, I can't use it for running (the main purpose for me) notifications are not being received! It's crazy for such an expensive piece of equipment. Please can you advise if I am able to return the product?
Best Answer11-04-2018 05:34
11-04-2018 05:34
Same problem here - they admit its a software fault they know about. Can't understand how they can continue to sell a fitness tracker that plainly DOES NOT work
Best Answer11-04-2018 05:51
11-04-2018 05:51
32.32.10.15 -Fitbit Versa
Galaxy S8 G950FXXU4CR11
Fitbit 2.82 (20213330)
You need to get this sorted asap -you are loosing so much good will and brand loyalty.
Best Answer11-04-2018 06:04
11-04-2018 06:04
Agree!
I use Motorola Android Droid turbo,
Firmware 32.32.10.15
App version 2.82
Constant GPS connection issues. I am on my 3rd replacement and none work consistently. I love the watch when it works (few and far between). I have been very patient. I really don't understand why Fitbit continues to sell new ones to consumers.🤔
Best Answer11-04-2018 07:28
11-04-2018 07:28
@MarcoGFitbit wrote:Hello everyone, I hope you're doing well.
- iPhone model you're currently using.
- OS version running on your phone
- Version of your Versa (in the Fitbit app tap on the picture of your Versa, on the next screen you will be able to find the version)
- App version currently installed on your phone (go to Account > Help to get it)
Phone: Moto E(4)
Android OS: 7.1.1
Versa Firmware: 32.32.10.15
Fitbit App Ver: 2.82 (20213330)
When tracking bike rides using connected GPS, on open road in the city, with the phone one foot from the Versa, the Versa continuously loses connection ("connecting" displays across the top) and fails to log mileage properly. Options for "Always Connected" and "Keep-Alive Widget" are both on. I have tried it with WiFi on vs off, with the phone location service set to GPS only vs high accuracy mode, opening and leaving active the Fitbit app on the phone, turning All-Day Sync off and on, tried it before and after deleting all other blue tooth devices from the phone, after rebooting the phone AND watch just before bike rides, turning power saving modes off on all blue tooth apps...all to no avail. Strava and MapMyRide log accurate mileage.
11-04-2018 08:01
11-04-2018 08:01
App 2.82
I have continuing GPS problems. On my 3rd replacement and none work. Love the watch when it works, rarely on bike rides. Can't believe Fitbit continues to sell Versa when they know it doesn't work.
Best Answer11-04-2018 10:34 - edited 11-04-2018 10:38
In regard to the connected GPS issues, perhaps some of you will find this useful. It does seem to work for me.
11-04-2018 10:36
11-04-2018 10:36
@Danc87 downgrade to Fitbit mobile app 2.74. All versions after this one killed my sync.
11-04-2018 13:31
11-04-2018 13:31
Best Answer11-05-2018 07:30 - edited 11-05-2018 07:33
@Marrrmaduke wrote:In regard to the connected GPS issues, perhaps some of you will find this useful. It does seem to work for me.
thanks @Marrrmaduke
Please let me know if this solutions works for any Oreo users.
For Samsung devices I have also commented how App lock for Samsung Android devices with Oreo update is to be done in reply section of @Marrrmaduke post
I will also try this solution tomorrow on my run & comment.
Best Answer11-05-2018 21:57
11-05-2018 21:57
I am using the iPhone X.
iOS 12.1
Versa version 32.10.15
Fitbit App 2.82 (800)
I hope you guys can get this fixed ASAP.
Best Answer11-06-2018 06:45
11-06-2018 06:45
I appreciate your participation in the Forums and for replying with the information requested. At this moment I have compiled all of the data you have sent and forwarded to our team so they can check it further and work on a resolution for this issue. @Marrrmaduke, I would like to thank you for your help and for sharing some troubleshooting steps.
I understand your concern about this issue, but please note that our team is actively working towards finding a resolution and every piece of information is very helpful for them.
Thanks again for your patience and understanding, I hope you have a great day.
Best Answer11-15-2018 07:21
11-15-2018 07:21
Phone: OnePlus 6
Android OS: Oxygen OS 9.0.2 (Android version 9)
Versa Firmware: 32.32.12.19
Best Answer11-15-2018 12:03
11-15-2018 12:03
@SunsetRunner If your Versa syncs without issues, this should work for you (hopefully) as you're on OP.
Best Answer11-26-2018 04:32
11-26-2018 04:32
Phone: Pixel 3 XL
Android OS: Android 9.0 (November 5th update applied))
Fitbit App Ver: 2.83 (20213333)
My issue seems to be connected GPS says 'connecting.....' if I have another device connected to my phone via BT, otherwise it's reasonably reliable for connected GPS.
However, I am surprised such a basic requirement of multiple devices connected is causing any issue. It's not as if BT is a new technology, it's over 20 years old now! I'm also very disappointed at Fitbit using a 4.0 received which is 7 years old version simply to save money and risk the issues that so many people are clearly having.
It's not really good enough when you spend a lot of money on their devices they should work!
Best Answer11-27-2018 14:47
11-27-2018 14:47
don't understand why FITBIT can't just go back to version 2.74.2 of the app and see what went wrong afterwards. As this one didn't have issues with GPS. They need to hire talents from APPLE to get this resolve.
11-27-2018 20:30
11-27-2018 20:30
@coolman78 Funny that you mention that... This is the most stable build for me as well...
Best Answer11-28-2018 06:17
11-28-2018 06:17
@coolman78, @Marrrmaduke I agree that 2.74.2 was the best app version for the Connected GPS feature. However, if my memory serves me right, 2.74 was the app version that totally ate data and cost people without unlimited data real money. Patches were added to 2.74 (2.74.1 and then quickly 2.74.2) that stopped the excessive data usage. Do we really want to work with an app version that was problematic with patches added on? Was it that heavy data usage that permitted the Connected GPS to work so well? That would be my guess. Also, that was the last version to run under Android 4.
I am also quite disappointed that this problem persists 9 months after launch and I've come to believe that "Connected GPS" while great is concept just won't work in practice. My next purchase will be a tracker with a built-in gps. To date, I don't care for the look of any gps-containing trackers on the market except for the AW and, since I don't have an iPhone, that one isn't an option for me. I'll continue to hope and watch for a real fix but I've stopped expecting it. ![]()
