08-24-2019
13:10
10:03
AlvaroFitbit
08-24-2019
13:10
10:03
AlvaroFitbit
My Versa is fully charged but the screen died this morning. I have tried the manual reset but it doesn't seem to be working. The tracker appears to be tracking, but no screen.
Thanks
08-24-2019
18:20
10:04
AlvaroFitbit
08-24-2019
18:20
10:04
AlvaroFitbit
Hi @CherylVersa I have flagged a moderator to come and help you.
Helen | Western Australia
10:06
08:20
08-25-2019
10:06
08:20
@CherylVersa A warm welcome to our Community!
Let me help you with your unresponsive Versa and thank you for restarting your device. Is your Versa still syncing? Do you see current the battery level on your app (noticed that you will see the battery level at the last sync)? This could be a battery issue so to discard this please try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves. You can also find additional suggestions here.
@NellyG thank you for your help here.
Let me know how it goes.
