08-27-2018
09:26
11:39
DavideFitbit
08-27-2018
09:26
11:39
DavideFitbit
My Fitbit has a strange orange line that's appeared down the side of the screen!? It's less than 6 months old! Any ideas? I've tried a restart but it's still there?
Moderator edit: format
08-27-2018 09:30 - edited 08-27-2018 09:31
Sorry to hear that.
You will need to return for replacement. Contact customer service.
08-27-2018 09:34
08-27-2018 09:34
Thought that might be the case! Thank you!
Best Answer07-05-2020 16:38
07-05-2020 16:38
You are lucky your device is under warranty so you can return it. My Versa started showing the orange line on the side and I did everything the customer service asked me to do but is didn’t go away. Around the same time I started having problem with changing hour in alarm and timer. Minutes side was fine. Customer service couldn’t resolve that issue either. Since the warranty had expired, they offered me 25% off to buy a new FitBit. Useless in my opinion!!
