06-06-2018
17:16
05:25
AlejandraFitbit
06-06-2018
17:16
05:25
AlejandraFitbit
I bought my Versa a couple days ago and have downloaded the Fitbit app to my iPhone. I followed the setup instructions for the Versa and get to the step where the watch is trying to pair with my phone. I input the 4 digit code form the watch into my phone and then the whole process stalls for hours. I have gone through all the troubleshooting steps I can find on the forums and nothing works.
I've restarted the watch, I've restarted my phone, I've turned Bluetooth on and off, I've uninstalled and reinstalled the Fitbit app ... not sure what else to try. I like the watch and would like to keep it if I can get it to sync up but I'll have to return it if it won't sync. Any suggestions are welcome.
06-07-2018 05:27
06-07-2018 05:27
It's great to welcome you @DGMacK.
Thanks for troubleshooting this by yourself and would like to know if you keep having issues pairing your Versa? If you do, I recommend taking a look at the help article Why can't I set up my Fitbit device? and follow the instructions provided there.
Let me know how it goes.
06-08-2018 07:48
06-08-2018 07:48
It took multiple tries over 4 days to get the Fitbit Versa set up initially on my iPhone 8 and it seemed to work well for 24 hours but today it won't sync again. It repeatedly starts to sync and then drops the bluetooth connection. I have deleted all other bluetooth devices so it's my only connection at this point. This is extremely frustrating because I like the watch and the features that it offers but if it won't deliver and function properly it's of no use. In reading the many posts this looks like a common problem so there must be a fix out there. Any feedback is welcome.
06-09-2018 05:01
06-09-2018 05:01
I tried downloading the FitBit app to my PC and syncing that way but I get an error message there that says I need to uninstall fitbit connect and any other apps that are interferring with the sync ... I don't have FitBit Connect loaded so I am at a loss as to what to look for or what is interferring but my watch still will not do a complete sync. It will sync far enough to pick up activities like steps etc. but won't sync the sleep data and Strava ride data etc. Anyone else having these partial sync issues?
06-24-2018 10:56
06-24-2018 10:56
I've had syncing issues with the Versa pretty early on. I thought it had been resolved, but yesterday I realized it hadn't synced since June 6th. I'm waiting to hear back from support, but you're not alone -- people are still having Bluetooth/WiFi/Syncing issues with Versa. I haven't had mine for 40 days yet and it's looking like a dud. If I'm asked to troubleshoot one more time I might lose it...but I'm also frustrated for the same reason you are -- I like the watch and its features. I know I can still get a refund, but why at this point is sunving and connectivity since a problem with the Versa? Fitbit is likely going to lose me if they can't get these issues with Versa figured out.
06-29-2018 08:31
06-29-2018 08:31
I feel your pain. I have a Droid Turbo OS 6.01 and went through the checklist of permissions they recommended. Nothing worked. I then turned on the NFC Option to allow data exchange when the phone touches another device and allowed the security reminder to default yes for that option. I tried to set up the Versa one more time after this change and it magically worked. I don't know if it will continue to sync properly but so far so good for the set up. I know my phone is older technology and that may be the cause of my problems.
07-02-2018 13:20
07-02-2018 13:20
After 2 weeks of frustration and trying everything I could find on the internet as well as suggestions from Fitbit mentor help, I finally took the Versa back to the Source where I had bought it. They offered me a new replacement watch or a refund plus offered me a full cash refund on the new watch if it didn't work properly ... so I took the replacement Versa and the entire installation process went flawlessly. It has been working perfectly for over 2 weeks now and I am very pleased with the product, it's a great smart watch when it works but it would appear that there are still quite a few quality control issues with the Versa and I would suggest that if it doesn't immediately install and sync properly ... take it back for a replacement or a refund (but I would still recommend the replacement option because if you get one that works, they really are a very good smart watch).
07-02-2018 13:48
07-02-2018 13:48
08-03-2018 11:03
08-03-2018 11:03
I bought my Versa through Amazon, and the first day it paired to my Iphone6, but wouldn't sync, so I started over and now it won't even connect with my phone. And please, fitbit people, don't send me a link to the troubleshooting. I've done all of that a million times. It gives me the 4 digit code, and then says it's "connecting" but never does. I've deleted and reinstalled fitbit, restarted my phone, restarted my watch, nothing works.
I've thrown out the packaging (stupid I know), am hoping they will still take it back and send a new one? This is driving me crazy.
@DGMacK wrote:After 2 weeks of frustration and trying everything I could find on the internet as well as suggestions from Fitbit mentor help, I finally took the Versa back to the Source where I had bought it. They offered me a new replacement watch or a refund plus offered me a full cash refund on the new watch if it didn't work properly ... so I took the replacement Versa and the entire installation process went flawlessly. It has been working perfectly for over 2 weeks now and I am very pleased with the product, it's a great smart watch when it works but it would appear that there are still quite a few quality control issues with the Versa and I would suggest that if it doesn't immediately install and sync properly ... take it back for a replacement or a refund (but I would still recommend the replacement option because if you get one that works, they really are a very good smart watch).
11-23-2018 13:14
11-23-2018 13:14
Hiya, how you succeed?, I am really annoyed same thing for me.. Is was à working after factory reset.. Until Friday 16 of Nov 2018.. Then didn't sycn anymore.. The watch alone it did work. But the app .
The more frustrating point.. Is the moderator... Repeat same info u just gave.. I think I will seel it in ebay and look for something else
12-01-2018 07:10
12-01-2018 07:10
I have same problem - iPhone XS Max - was all working until last Wednesday and since then refusing to pair - very frustrating and tried all the uninstalling switching off and on etc my phone won’t pick it up at all but it picks up other Bluetooth so it is not the phone - deleted all the other Bluetooth and it still not picking up my versa ...... any ideas anyone
12-01-2018 12:23
12-01-2018 12:23
12-01-2018 12:39
12-01-2018 12:39
I'm having problems with mine too... it won't sync past today, so I have no data from yesterday according to the app... I've reset it, unpaired it and nothing seem so to be working.
12-02-2018 01:09
12-02-2018 01:09
12-02-2018 05:39
12-02-2018 05:39
@Chucarita @Eliz08 @sandracvrt Welcome! It's great to see you around! Sorry to hear that your Versa isn't syncing with your phone. You can try going to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device. After this try syncing them. Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on.
Let me know how it goes!
12-02-2018 07:51
12-02-2018 07:51
12-02-2018 07:56
12-02-2018 07:56
I called FitBit yesterday, and they were able to help me get everything reset - seems to be working just fine at the moment.
@Eliz08 wrote:
I have done all this I’m afraid no success - however just now it synch with my iPad and by magic synch with my phone !!! So very happy - for those out there with similar problem try synching with your tablet then hopefully same thing will happen!
Sent from my iPhone
12-02-2018 07:57
12-02-2018 07:57
05-29-2019 04:30
05-29-2019 04:30
May 29, 2019 tried the nfc suggestion after doing all the troubleshooting steps and it worked
05-29-2019 05:27
05-29-2019 05:27
