06-23-2022
01:26
17:53
06-23-2022
01:26
17:53
Just bought my new fitbit tried using direct through web page and app will not allow me to look at my account or sync all its saying is "fitbit.com unavailable at this time. Please try again later" I keep trying and no joy I've shut down and restarted and uninstall and reinstalled whats happening?
06-23-2022 03:56
06-23-2022 03:56
Hi @MelsSteps86 - if you are getting this on your phone it may be a security issue.
You can try using a mobile only connection [by turning of wifi], which may work..
Even though you have a normal Internet wifi connection there are some specifics that may need addressing, see No internet connection.
Also a reboot of the phone can sometimes help, along with ensuring that you have phone GPS on.
06-23-2022 07:29 - edited 06-23-2022 07:30
Hello @MelsSteps86
If the suggestions of @Guy_ doesn’t do the trick try to clear you app data. Go to your phones Settings then tap Apps. Find Fitbit then tap Storage, then tap storage. Tap clear cache if you happen to have an Android phone.
06-23-2022 08:35 - edited 06-23-2022 08:36
I'm wondering if this was caused by Fitbit apparently switching off some app services yesterday for a period of time...
Does it work for you now?
