01-02-2020 08:29
01-02-2020 08:29
Versa is showing 100% charge while connected to charger , it every syncs but when removed from charger it goes blank. When connected again 0% is displayed on screen. I have tried cleaning contacts, charging from different ports too. Any help??
01-02-2020 09:06 - edited 01-02-2020 09:13
Hi @LPraveenKumar , did you already tried to restart your Versa three times in a row (internal reset)? If yes, and the problem is not solved, please contact Customer Support and ask for a battery test. Regards kuzibri
01-02-2020 09:32
01-02-2020 09:32
How to restart when it's not switching on
01-02-2020 10:22
01-02-2020 10:22
Hi @LPraveenKumar , try the two button method, e.g. press and hold the left and right lower buttons together untill you see the Fitbit logo and release the buttons. If that's not possible or working, you're sure to contact Customer Support. Regards kuzibri
