11-06-2025
13:40
12:06
JuanFitbit
11-06-2025
13:40
12:06
JuanFitbit
I was trying to log my food today and it will not show any food when I put an item in. It will also not show anything in the database when I scan and I know those items are in there. Please help. I have a sense 2 and an apple
Hi everybody! Thank you for your messages and feedback. I'm glad to read that this has been solved for some of you.
Our team has informed me that this should be solved by now. Please make sure that you have the latest Fitbit app installed.
If you are still having the issue, please try turning your phone off and on again.
We'll keep the thread open for any feedback and to see if anyone is still having the issue.
We appreciate your collaboration and patience whilst our team worked on it.
Tried logging food today and my barcode scanner is gone and when I try to search for food, nothing happens. Reinstalled software, factory reset on Versa 2, rebooted phone, nothing. Tried to select a food day and it says n/a with no other options. Worked fine last week. Help. I'm going crazy and want to throw the phone out the window.
Forgot to mention I ever tried on an iPhone and no luck
Sorry food database not food day.
11-06-2025
18:30
20:33
EstuardoFitbit
11-06-2025
18:30
20:33
EstuardoFitbit
I am in the USA and having the same issue. I also have the Versa 2. I have uninstalled and reinstalled the app twice. I have rebooted my phone each time I did this before reinstalling. I have removed the food tile and added it back. Nothing works. My guess is after the latest update something went wrong (my app says it updated 16 hours ago and worked for me fine until about an hour ago then the database disappeared). I also went into the Today tab, clicked my profile pic in the top right, went to Fitbit settings, then down to Nutrition and Weight, then to Food database at the bottom and I see text that says "A food database for United States is not currently available. You can still create your own custom foods to log and track what you eat. " There must be some issue. Maybe the server that stores the database is down? I have no idea. It's very annoying because they don't publish information letting people know it's an issue you just have to guess what's wrong.
Sorry correction, I have a Sense 2 not a Versa 2.
I have an iPhone 12.
Having trouble with the food log for at least 9 hrs now, did the restart, log in log out and update the software. It's really the fit it server, hoping for the quickest response, Thank u
11-07-2025
01:52
03:58
CrisVillaFitbit
11-07-2025
01:52
03:58
CrisVillaFitbit
My fitbit-app has no connection to the food database since yesterday. I'm not able to scan a barcode. Is this a temporarily problem?
Moderator edit: edited title to clarity.
It seems to be an backend problem and NOT an frontend app/ mobile phone issue. I installed an older version of fitbit Android app and it remains as it was. The same with iOS. Food data base does not work and the barcode scanner is still not there... It's up to Fitbit to fix it.
Many thanks in advance for your efforts 🙂
Best AnswerSame. This started sometime on 11/6/25 after 1:00pm ET. Reinstalled app, reboot, switched signals, etc. Its all not working. The only option for database is "N/A". Need Fitbit team to hotpatch this.
