08-03-2020
04:04
05:21
JuanJoFitbit
08-03-2020
04:04
05:21
JuanJoFitbit
My Fitbit versa 2 screen is covered suddenly in static tv-like fuzzy lines and is not responding!
Moderator edit: format
12-19-2021 15:41
12-19-2021 15:41
I’m sorry to say it’s probably terminal. They replaced mine under warranty for it. I think it’s a battery/motherboard issue.
Best Answer12-19-2021 17:07
12-19-2021 17:07
Best Answer12-19-2021 18:12
06-04-2022 22:57
06-04-2022 22:57
Hi
This happened to my versa 2 with staticy lines on and off for couple of days then went totally black.
I recharged it over night not knowing what battery status was due to black screen.
Then held in the button for about 10 seconds until it vibrated. I could then just faintly make out the fitbit logo on the watch screen......just.
Noticed it was no longer connected to my Android fitbit app and no longer syncing. I tapped the top left hand icon of the app then opted to add new device.
Followed the screen prompts to "add" it in again. This took about 90 minutes as no internet. The progress bar was fully visible so was getting excited at this stage. Finally it then wanted to update firmware so followed the prompts. Then a few standard set-up options and what da yu know it worked. My versa 2 is now fully functional as it was previously.
Not saying this process will work for everyone but my versa 2 went from full static screen to totally black and useless to working perfectly. I'm not technical, just a user, these steps worked for me and I hope they work for you as well. Jazz
Best Answer11-06-2022 13:36
11-06-2022 13:36
I’ve had enough! Too many issues. Off back to my everyday standard watch.
I paid nearly £200 for the Vera’s 2.
Not doing what it’s supposed to now.
04-04-2023 04:00
04-04-2023 04:00
I'm on my 2nd versa 2. Same happened to my 1st one around 18m ago. I hadn't had that one too long so it was still covered by a 2 Yr warranty. The 2nd one is doing exactly the same but sadly they say warranty isn't 2 years on replacement so 2nd watch was just tagged on to original warranty which means it was only covered for around 6 months. I'm Gutted because they're not cheap to buy and quite frankly I expect more than 2 years from them. They've offered me a 35% discount on a new one but I'm thinking of trying out a Samsung or a Garmin. Really disappointed and will be very sad leaving fitbit but I'm not happy with the life span of their products.
04-05-2023 14:18
04-05-2023 14:18
