06-13-2018
21:55
16:48
EdsonFitbit
06-13-2018
21:55
16:48
EdsonFitbit
I want my steps to reset at 3am instead of midnight. I searched for an answer and I found people asking the same thing as far back as 2014. Is there a fix yet?
Moderator edit: added label
06-13-2018 23:26
06-13-2018 23:26
There's still no way to change the time of the daily reset. I'm not sure that fitbit see it as a problem to be fixed - it's working as they intended.
There is a popular feature suggestion for this change to be made. If you'd like to add your vote it can be found here: https://community.fitbit.com/t5/Feature-Suggestions/Edit-Time-of-Daily-Reset-of-Stats-Add-Nightshift...
Note though fitbit's comment that they currently have no plans to make the change.
