04-04-2019
14:29
11:42
AlessFitbit
04-04-2019
14:29
11:42
AlessFitbit
I have just installed the new Bitmoji clock face and by default the date is displaying as mm/dd. I live in Australia and we recognise our date format as dd/mm. Is there a way to change the date format?
(Note - My FitBit profile is set to an Australian timezone)
Moderator edit: title for clarity
04-05-2019 14:52 - edited 04-05-2019 15:07
UPDATE!
@Bingsmate they have added a date format so you can change it now to dd/mm. It's underneath the bit in the bitmoji clock where you can change your background. Hope this helps.
If you installed the bitmoji face yesterday before the update you'll need to do an update then you'll see the date format option
04-04-2019 14:34
04-04-2019 14:34
I'm sorry I can't help! Mine won't download at all!!! Is there a secret trick you used? lol
Best Answer04-04-2019 14:50
04-04-2019 14:50
Hi @Tammy2014 I just popped over to the other thread where lots of people including yourself seem to be having trouble getting it to work. I had no trouble installing mine (probably not what you want to hear lol!).
It did take maybe 5 minutes for the "teleporting" to finish but that was to be expected. I am sure they will try and fix asap since a lot of people seem to be having issues.
Sorry I cant be more help to you either! 🙂
Best Answer04-04-2019 15:02
04-04-2019 15:02
Thanks @Bingsmate . I was so excited to see it that I even downloaded Snapchat (been a resister for YEARS!). So sad 😞 lol
04-04-2019 15:33
04-04-2019 15:33
@Bingsmate Hey, there! Excited to hear you successfully downloaded the Bitmoji clockface. ![]()
As far as the date format, you cannot change it for the Bitmoji clockface. The date format is always dependent on the clock face (some do offer different formats in settings) so just depends on which one you have chosen that offers this option.
Hope this clears it up for you!
Best Answer04-04-2019 20:04
04-04-2019 20:04
Would be nice if it's not always in a US format and other countries are considered. A similar thing happened with the weather app for the UK. eg the units we use are feet inches, stones, miles, celsius but we had to put it to a vote to get celsius as an option as it would tell us temperature in Fahrenheit. Again were in a dispute. Date in the UK we would use : Friday 5th April. So it can get very confusing and easily mistakes can be made.
link below is to vote for a UK/AUS date format for bitmoji clock face
Best Answer04-05-2019 14:52 - edited 04-05-2019 15:07
UPDATE!
04-05-2019 16:04 - edited 04-05-2019 16:05
Thanks @lexi83 for letting me know! I have just applied the update and can change the date format! So happy now! 🙂🙂🙂
04-06-2019 11:41
04-06-2019 11:41
@lexi83 You're so quick! Thanks for letting everyone in this thread know that there was a Bitmoji clockface update yesterday. With this update, you can now adjust the format for how you see the date.
Please make sure you're using the latest Bitmoji update! 😀
Best Answer05-09-2019 12:08
05-09-2019 12:08
How did you change the clock face to Bitmoji. The watch is telling me to visit the clock face settings on my phone to connect Bitmoji through Snapchat??
