04-04-2019
21:18
09:37
MarcoGFitbit
04-04-2019
21:18
09:37
MarcoGFitbit
This is a replacement for the one I bought not quite a year ago. The face of the watch is very dim compared to the older one. I have an apple phone. Does anyone know how I can brighten the face?
Thank You,
Miriam
04-05-2019 05:06
04-05-2019 05:06
Hi @Your2kind. And welcome to the forums! The brightness on the Versa can be adjusted. Swipe to Settings, then scroll down to Brightness. You can choose between Auto, Max, Normal and Dim.
04-05-2019 05:06
04-05-2019 05:06
04-05-2019 07:41 - last edited on 03-09-2020 16:05 by LiliyaFitbit
Thank you for your response! Nice to know this as it makes all the difference in the world.
Thank you, Miriam
"The best and most beautiful things in the world cannot be seen, nor touched...but are felt in the heart"
Hellen Keller
10-13-2019 07:21
10-13-2019 07:21
What if there is no brightness option ?
10-20-2019 19:30
10-20-2019 19:30
My versa watch has a brightness setting of dim but no option to change it???
10-27-2019 13:03
10-27-2019 13:03
No success. I swipe to settings and scroll to brightness. It’s on Dim and no amount of touching will change it.
11-03-2019 18:15
11-03-2019 18:15
Hi "dfmgerardi". I had (I think) the exact same problem. Brightness set to "Dim" in settings & the Brightness control inaccessible (greyed out)...
The solution for me was that the watch was in "Sleep Mode", which locks out the Brightness controls & forces "Dim". If this is so, take it out of Sleep Mode & all is normal again….
11-04-2019 06:20 - last edited on 03-09-2020 16:08 by LiliyaFitbit
Thanks for the suggestion. The sleep mode option didn’t do it for me. I ended up calling customer support and by phone we went through several attempts until finally reinstalling Versa via Wi-Fi which fixed the brightness problem.
I’ve simply given up trying to use the music app. The volume control doesn’t respond. Not worth the bother since I always have my iPhone with me with playlists.
Cheers,
Don
11-04-2019 12:24 - last edited on 03-09-2020 16:07 by LiliyaFitbit
I figured out how to increase the screen....thank you all!
Hellen Keller
Moderator edit: personal info removed and all-caps
11-16-2019 08:55
11-16-2019 08:55
Dim mode on Versa. Solution I found. Apparently after update or I did it by mistake but after much research and experimentation, I found out that if your sleep mode, on yourVersa, is on then the dim mode is always on. I located the sleep mode it looks like a crescent moon and turned it off on my Fitbit. By holding in the left button I found the sleep mode indicator. By holding in the left button I found the sleep mode is located which looks like a cresant moon. If it is highlighted touch it to turn it off. Now the dim mode is also turned off. I hope this helps.
11-19-2019 11:26
11-25-2019 11:53
11-25-2019 11:53
This did not help me. When I touched brightness it would not change. I figured out that my phone was in sleep mode ( I have no idea how I did that) I took it out of that and it went back so bright immediately. Go to settings ... go down until you find “Sleep Mode”. Turn it off and it will go to bright or you will be able to change to bright with the brightness tab that’s first under settings.
12-02-2019
14:20
08:13
DavideFitbit
12-02-2019
14:20
08:13
DavideFitbit
My Versa Lite screen is suddenly dim. It was fine a week ago. Versa is charged. I went to settings and scrolled down. There is nothing that will increase the brightness of the screen. I know I've seen it, but can't find it. Please help!
That is what was wrong with mine! Thank you! Thank you! Thank you!
14:41
17:15
LizzyFitbit
12-02-2019
14:41
17:15
LizzyFitbit
I called Fitbit and got telephone help to reinstall the watch to deal with the problem. Give that a try.
Moderator edit: removed personal information
Best Answer12-02-2019 15:38
12-02-2019 15:38
@dfmgerardi - Please tap the three dots at the top, right of your posting, then tap Edit to remove your personal information. This is a public forum. I’d hate for you to start getting a lot of spam!
Best Answer12-03-2019 09:00
12-03-2019 09:00
12-08-2019 11:10
12-08-2019 11:10
Mine is grayed out and I cannot change it from dim
12-10-2019 11:59
12-10-2019 11:59
Since posting this after getting telephone help dealing with brightness issues the problem
has recurred. It’s stuck on Dim. No amount of synching helps. I regret buying the watch. It tries to offer more than it can deliver and there’s little support. This community forum is not a substitute.
12-10-2019 12:01
12-10-2019 12:01
17:18
08:14
DavideFitbit
12-10-2019
17:18
08:14
DavideFitbit
The point is that simply does not work. Hitting on brightness it remains dark and no amount of tapping on it will give access to a choice.
Exactly!
