11-13-2019
12:36
04:38
JuanJoFitbit
11-13-2019
12:36
04:38
JuanJoFitbit
I have a Dexcom G6 to monitor my blood sugar. Does anyone know if I can use a Versa 2 to Display my blood sugars from my Dexcom G6?
Moderator edit: format
After you e down loaded the glance clock face. Tip one look up your Dexcom account user name and password in your password settings on your iPhone. Check your user name on your Dexcom app. Make sure these are correct I’m your Fitbit glance settings. Tip two click the international button if you are outside America. Mine finally worked straight away when I did this. Yeah!
Best AnswerI'm a long-time iPhone and Android G6 app user, but like the slimness of the Fitbit. Do they update their OS so any Fitbit will work with the apps mentioned, or what Fitbit models will worth with the graphic apps mentioned? Thanks!
Best AnswerAll of the smartwatches will work. In other words, the Versa 2, Versa 3, or Sense.
Best AnswerHi, SunsetRunner! I'm trying to help my mom through the process of downloading the app you suggested but we're stumped. We just paid for the app and are lost after that. Do you happen to know/remember how you downloaded it? We think we have to put information in Share on the Dexcom side of things but it's telling us that Fitbit is not supported. Any advice?
