-3/20/2020
Fitbit Versa 2, bought Dec 2019. I wear it to sleep, which should not affect watch, but now the left button only responds sporadically and when watch screen is visible (also sporadic) there is no response to navigating from watch view to other sub-menus. Wonder if I need to reset some setting... and how... or if Fitbit has gone kaputz.
Thank you for any suggestions! Be safe out there!
Alex
@Alex-25 At this point I would attempt performing a factory reset. Unfortunately you will need either screen or buttons. Before factory reset, make sure you have deleted versa your phone's Bluetooth settings (not Fitbit app). To perform factory reset, open settings app on you Versa and scroll down to About. Tap it and choose factory reset. This will wipe all data from your tracker so it would be good if you could sync it first. After factory reset you will need to set up your versa again by adding a replacement device in your Fitbit mobile app.
If you cannot use the screen, please try using the back button:
You can set up the watch back to the Fitbit account by following the instructions on this link: How do I set up my Fitbit device?
If you're not successful with the factory reset, I am afraid you will need to reach out to Customer Support to guide you through the next steps. Here's the link to Customer Support page. Fortunately, your Versa is still under warranty.
Best Answer@Alex-25 At this point I would attempt performing a factory reset. Unfortunately you will need either screen or buttons. Before factory reset, make sure you have deleted versa your phone's Bluetooth settings (not Fitbit app). To perform factory reset, open settings app on you Versa and scroll down to About. Tap it and choose factory reset. This will wipe all data from your tracker so it would be good if you could sync it first. After factory reset you will need to set up your versa again by adding a replacement device in your Fitbit mobile app.
