05-04-2020 03:44
05-04-2020 03:44
I do not have unlimited data on my phone. How do i make sure my Versa is not syncing without wifi connection.
05-04-2020 09:58
05-04-2020 09:58
That's not a function of the tracker. Only thing I can suggest is that you turn off mobile data on your phone.
One thing I have noticed on my phone (Pixel 3) is if I go into settings/apps/fitbit/mobile data & wifi I have an option called "background data" to enable usage of mobile data in the background. Maybe turning that off will help?
Best Answer05-04-2020 10:31
05-04-2020 10:31
Turning off background data on your phone app settings will not stop the Versa 2 from using your cell data.
I believe as long as the Versa 2 is connected via Bluetooth to your phone, it will be able to use data and there is no way around this. It is very annoying for those of us who would like to use the watch as intended and frequently. Not everyone has huge data allowances on their phone plan but Fitbit seems to not care.
05-07-2020 11:24
05-07-2020 11:24
I agree. I would have never purchased this product if i would have known prior.
05-07-2020 21:14
05-07-2020 21:14
New to this whole FitBit thing myself. Will it still use phone data if you shut off all day sync in the FitBit app?
Best Answer05-07-2020 21:28
05-07-2020 21:28
I guess my other question would be, just how much data does this watch use with the constant syncing? I to don't have unlimited data and am now curious.
Best Answer05-08-2020 06:26
05-08-2020 06:26
