Hey! I was planning to buy Fitbit Versa but I didn't see my device i.e. Motorola One Power listed as a compatible device. So I'm in a fix whether to go for it or not. If it's not compatible, what compromises do I exactly have to make? Is it worth it?
My Motorola One and Versa works without Problems.
10-14-2019
12:56
06:48
10-14-2019
12:56
06:48
@Shreyas13 Welcome! Thanks for being part of our Community! Sorry for the delay in my reply.
Thank you for your inquiry. Your phone doesn't show as compatible but that doesn’t mean it won’t work it just means that it hasn’t been tested by our team. Still you could try the Versa and see how it works for you. Many stores have a return policy or you could purchase it from the Fitbit store that gives your 45 days to return the device.
Let me know how it goes.
08:23
06:48
10-15-2019
08:23
06:48
@AGRASSE hope you are fine.
Thank you so much for sharing your experience with your phone and your Fitbit device. Hopefully this information will help other members with the same phone.
I'll be around.
09:21
06:48
10-29-2021
09:21
06:48
@Supermor I hope you're doing well.
Sorry to hear about this. Have you tried any troubleshoots? You can try the following:
Best AnswerI bought at fitbit versa - but it will not connect to my Motorola One phone eventhough the phone is the newest model. Is there at way to fix it?
