10-12-2019 12:26
10-12-2019 12:26
Hey! I was planning to buy Fitbit Versa but I didn't see my device i.e. Motorola One Power listed as a compatible device. So I'm in a fix whether to go for it or not. If it's not compatible, what compromises do I exactly have to make? Is it worth it?
10-14-2019 13:09
10-14-2019 13:09
My Motorola One and Versa works without Problems.
10-14-2019 12:56
10-14-2019 12:56
@Shreyas13 Welcome! Thanks for being part of our Community! Sorry for the delay in my reply.
Thank you for your inquiry. Your phone doesn't show as compatible but that doesn’t mean it won’t work it just means that it hasn’t been tested by our team. Still you could try the Versa and see how it works for you. Many stores have a return policy or you could purchase it from the Fitbit store that gives your 45 days to return the device.
Let me know how it goes.
10-14-2019 13:09
10-14-2019 13:09
10-15-2019 08:23
10-15-2019 08:23
@AGRASSE hope you are fine.
Thank you so much for sharing your experience with your phone and your Fitbit device. Hopefully this information will help other members with the same phone.
I'll be around.
10-21-2021 08:27
10-21-2021 08:27
I bought a Fitbit Sense and it won't connect to my new Motorola one phone. Really frustrating!!! Now I'm just hoping the shop will let me return it even though the box has been opened.
10-29-2021
09:21
18:30
10-29-2021
09:21
18:30
@Supermor I hope you're doing well.
Sorry to hear about this. Have you tried any troubleshoots? You can try the following:
12-12-2021 04:57
12-12-2021 04:57
I bought at fitbit versa - but it will not connect to my Motorola One phone eventhough the phone is the newest model. Is there at way to fix it?
12-12-2021 04:58
12-12-2021 04:58
It didn't help. It doesn't work.
12-12-2021 06:30
12-12-2021 06:30
Was the setup also done via the Fitbit app at the beginning? otherwise it won't work
