09-09-2019 08:15
09-09-2019 08:15
I keep getting the notification that “Fitbit was unable to update/install one or more apps” what is this about and how does it get fixed. Everything appears to be working.
09-11-2019
10:13
09:27
09-11-2019
10:13
09:27
@JaeJaeH Welcome! It's nice to have you on board! Sorry for the delay in my reply.
Let me help you updating your Versa's apps. Start by logging out from the Fitbit app, restart your phone and log back in. This could also be due to the app being discontinued by the original developer. Check the apps you have installed and see if you have any updates for them. You could try restarting your Versa then making sure all apps are up to date.
Let me know how it goes.
Best Answer09-11-2019 10:38
09-11-2019 10:38
Hi, could you be a bit more specific, e.g. what apps are the problem, etc. Regards kuzibri
Best Answer09-12-2019 07:51
09-12-2019 07:51
Best Answer09-12-2019 07:53
09-12-2019 07:53
Best Answer09-12-2019 08:06
09-12-2019 08:06
Hi, the syncing problems are the result of an update of the Fitbit app. It looese sometimes the connection with the Versa leading to sync problems. Fitbit is aware of this issue and is working on a solution. For the moment, the only thing you can do is: quit Fitbit app - restart your Phone - start Fitbit app again. For certainty you can also log out before quitting and login after restarting. works for me. Regards kuzibri
09-12-2019 14:39
09-12-2019 14:39
