11-26-2019 04:02
11-26-2019 04:02
I did the update and ever since, my versa will not sync to the app, cannot connect to any wifi or bluetooth, will not hold charge, will not update at all. My versa has completely stopped working as soon as it finished the update. How do I fix it? This is very frustrating because it was working perfect until then ☹️
11-26-2019 04:04 - edited 11-26-2019 07:12
Did you try restarting it?
Hold the back button and bottom button together until the FitBit logo appears and then release.
Failing that, a factory reset. I have a Versa 2 but I did have a Versa a few months ago and if I remember rightly that can be found in Settings, About, then scroll down to factory reset.
Be sure to sync first if you can. Any un synced data will be lost if you don't do this before performing a factory reset.
Best Answer11-26-2019 08:45
11-26-2019 08:45
Which update, phone, Fitbit app or Versa?
Best Answer11-26-2019 09:39
11-26-2019 09:39
Best Answer11-26-2019 18:21
11-26-2019 18:21
