01-01-2019 18:34
01-01-2019 18:34
I’ve update my watch to OS 3.0 and of the seven options with a box to check, I’ve only got three: Core Stats, Hoirly Steps, Heart Rate.
I also cant input water stats either. Please let me know how to get these working.
Thanks!
02-10-2020 13:21
02-10-2020 13:21
It did not work!!! There were no updates available, and i rebooted it but it still won't work! If i uninstall my Fitbit app, will all my data be deleted??
Best Answer02-12-2020 06:12
02-12-2020 06:12
No, @Aj777 , uninstalling your Fitbit app, then re-installing it will not delete your data.
Best Answer05-14-2020 07:10
05-14-2020 07:10
Yes uninstall, follow the steps above, goodluck
Best Answer05-22-2020 12:58
05-22-2020 12:58
I tried this but it still did not work. There are no updates available for the today app. After reinstall and restart I am still only seeing 3 activities available.
Best Answer07-07-2020 10:44
07-07-2020 10:44
If i uninstall the fitbit app. will i lose my account? what will happen?
Best Answer11-28-2020 09:54
11-28-2020 09:54
You can not uninstall or change this way
Best Answer11-30-2020 03:20
11-30-2020 03:20
Hi, I'm having the same issue with my new versa 2 and it's driving me crazy. So, just wondering if you found a solution?
Thanks 😊
Best Answer12-07-2020 12:03
12-07-2020 12:03
I tried these steps for my versa 2 but still, it's not showing all stats.
The tracker is only showing 3 stats to choose from (Activity, Hourly Steps, and Heart Rate). None of the other stats are even showing up to choose them.
Best Answer12-07-2020 12:08
12-07-2020 12:08
Forget to mention, it shows all stats in the previous firmware version but after updating to the latest firmware(35.71.6.19), they are not showing up.
