04-13-2018
11:40
08:21
RobertoME
04-13-2018
11:40
08:21
RobertoME
Getting duplicate notifications, but not every one. Versa has 32.32.4.19. Android App is V2.69. Google Pixel, stock Android v8.1.0. All day sync is on, default notifications (no other apps enabled), Always Connected is on, Keep-alive widget is on. I see from other forums that this is a common issue among most trackers, but I don't remember seeing the issue with my old Blaze using the same phone/OS.
Moderator Edit: Updated Subject For Clarity.
04-25-2018 10:41
04-25-2018 10:41
I am having the same issue with Gmail and I am also using a Samsung7 phone I am using 32.32.4.19 version on my Versa. I did try the instructions in a previous post and also tried clearing all of the notifications. I still receive multiple notifications when an email comes through. I am not experiencing it with the text notifications at all.
04-26-2018 12:40
04-26-2018 12:40
Is there any fix for the duplicate message notifications on the versa? I've tried all of the troubleshooting mentioned and was also on the Fitbit chat earlier today with no success. Any other suggestions? Happens with text, yahoo mail and oulook for me.
04-26-2018 14:35
04-26-2018 14:35
This is _very_ frustrating... Duplicate notifications all the time. Worst offender is definitely email. In fact it's so bad I've now switched off email notifications which flood my poor Versa with duplicates regardless of what I do. Almost certainly an app issue and desperately needs fixing.
04-27-2018 11:03
04-27-2018 11:03
I have a Galaxy S7 and I am getting duplicated notifications for emails and texts and it is killing the battery life on my Versa and is absolutely frustrating. I don't want to have to dismiss the email or text notification 3 or 4 times in a day! Please fix this!
04-27-2018 12:54
04-27-2018 12:54
Is anyone else getting multiple notifications? I reported this yesterday and am curious if I'm the only one. I use Outlook. I can set an appointment on my calendar, using either my pc or my phone, and Outlook will notify me 30 minutes prior to the appointment. That shows up on my phone just fine, and it also shows up on my Versa. If I don't clear the notification from the phone, it will just count down the time. When I look at the phone I see 30 minutes util appt, then a minute later I see 29 minutes, then 28, and so on. It's a single notification on the phone and the time counts down. On the versa I get the first notification that it's 30 until the appt., but then every time the phone ticks off a minute the Versa gets a completely separate notification. So, on the phone it's a single notification that counts down by the minute and on the Versa it's 30 separate notifications. Once I clear the notification from the phone, the process stops. I was expecting something a little better.
Best Answer04-28-2018 15:28
04-28-2018 15:28
Best Answer04-30-2018 09:17
04-30-2018 09:17
I get 2 notifications for every one text.
Is this a setting I have wrong ?
Best Answer04-30-2018 09:29
04-30-2018 09:29
I'm seeing that same issue but for emails. I receive two notifications for every one email. Texts are working fine for me...
Best Answer04-30-2018 09:54
04-30-2018 09:54
@MintSneezy wrote:I'm seeing that same issue but for emails. I receive two notifications for every one email. Texts are working fine for me...
Ditto. I've been ignoring it, but it's a tad annoying.
Best Answer04-30-2018 10:01
04-30-2018 10:01
I am getting text notifications twice and I decided it is because a text sends a notification a 2nd time if you don’t open it after the first notification. If you open your text message after the 1st notification, I don’t think you will get a second one. I am not sure about double emails...
Best Answer04-30-2018 10:12
04-30-2018 10:12
I got double text notifications for a while. Then I realized that I had some apps that also text me, so I was getting the App notification along with the extra text it sent. I deleted the Apps from the notification list and all is now good.
Best Answer05-02-2018 10:33
05-02-2018 10:33
HI there everyone, Thank you all for keep reporting this issue and bringing to my attention the behavior of duplicate notifications. Just a heads up, I have merged some of your post in one thread to keep a better scope of this issue.
I would recommend to review what @swim4lifekac kindly suggested here. This can be an explanation why you are receiving duplicate notifications.
Also as an additional note, make sure to install the new version of the Fitbit app. if the update is not in the Google Play store yet, review at a later time. This update will gradually appear to all our Android users. For more details please refer to our post: Android app version 2.71 is now available - 5/1
See you later and as always, let me know any change of this issue.
Best Answer05-02-2018 10:42
05-02-2018 10:42
I don't have any other apps sending me notifications besides the default ones (GMail, Calendar, SMS, etc>). and 2.71 is NOT on the play store -- 2.70 is.
Best Answer05-03-2018 06:32 - edited 05-03-2018 07:02
Fixed this (so far) by disabling email from the main settings menu and enabling Gmail notifications from the app notifications menu. Im guessing because the Gmail notification option is greyed out in the app notifications menu when email notifications is enabled on the main settings menu that the duplicates are coming from Gmail notifications essentially being enabled twice (once in main settings and once in app notifications)
EDIT: this does not work, it just delays notifications so it appears to work until the notifications catch up
Best Answer05-04-2018 09:22
05-04-2018 09:22
Downloaded V2.71 app last night. Rebooted my phone and Versa. STILL have duplicate notifications. What is the timeline to get this fixed?
05-11-2018 11:23 - edited 05-11-2018 11:26
I also have updated to 2.71 and have tried restart, EVERYTHING. Still double email and text.
Using gmail and have a LG G6 phone.
Best Answer05-15-2018 08:56
05-15-2018 08:56
Versa took a download yesterday V32.32.10.15. Looks like they fixed the duplicate notifications by changing the entire user interface. I'm still trying to figure it out, but at least i'm not getting multiple notifications for emails anymore.
Best Answer05-15-2018 09:29
05-15-2018 09:29
I'm sorry but what does this mean? What "took a download"? Your Versa watch received a new firmware? Your iOS app got updated? Your Android app was updated? They fixed the double notifications by "changing the entire user interface"?
Best Answer06-08-2018 18:00 - edited 06-08-2018 18:01
Fitbit, this is absolutely ridiculous.
People have been complaining about this issue for months and the best your representatives have come up with so far is the Bluetooth equivalent of “turn it off and on again”. Which I can tell you is patently not going to fix this issue. This is an app issue, plain and simple.
Having said that, I have tried all of the ridiculous suggestions made by your representatives in this thread, and NONE of them work. At seemingly random intervals, my Versa repeats a stack of my previous notifications. So far I have received some notifications about emails during the past week (I’ve only had my Versa for a week) tens of times.
Basically it it makes my new Versa UNUSABLE as a smart watch.
I am running firmware 32.10.15 and iOS app version 2.51(764), both of which are the latest for today 9th June. 2018.
If you can’t tell us that this is going to be rectified now then I will have no choice but to exercise my rights as an Australian consumer and return it as “not fit for purpose”.
06-08-2018 19:05
06-08-2018 19:05
