04-05-2020 08:02
04-05-2020 08:02
Supposedly my Versa should have the SP02 function working. I am not seeing it as active. Oxygen levels can be helpful in relation to the current Covid concerns. Any idea when this may be updated or made active?
04-06-2020 19:17
04-06-2020 19:17
Hi @ith0 It is active. Go to your sleep tile in the app and select the night you and interested in. Scroll down to and select Restoration and then scroll down to the Estimated Oxygen Variation graph
Helen | Western Australia
04-06-2020 19:17
04-06-2020 19:17
04-09-2020 07:19
04-09-2020 07:19
Took a bit to find but all good now. Thank you
04-09-2020 08:58
04-09-2020 08:58
Not where youd immediately look!
04-09-2020 09:01
04-09-2020 09:01
Restoration only appears when you have Fitbit Premium ( paid service ). My chart used to live below the sleep graph, but then it disappeared, only to come back a few days later and then disappear again. Currently, it is missing again (4-9-20). FRUSTRATING!!! Especially since I updated my perfectly well functioning Blaze to the Versa 2 JUST TO GET THIS FEATURE! Updated my husband’s Blaze as well, and his works just fine all the time! As though he cared . . . How ironic! Hey Fitbit, is this just a ploy to get us all who want this feature to sign up for Premium? I just forked over 200 bucks to upgrade my device and the reason I did this IS NOT WORKING!
05-01-2020 22:35
05-01-2020 22:35
I received a notification awhile back, that they were giving the Premium for free during the pandemic - I just checked - and I don't have an option anywhere for SP02. If it truly tracks this, I would pay for Premium!
05-02-2020 01:08
05-02-2020 01:08
Premium isn't required for basic SPO2 readings. If the watch detected enough sleep to show sleep stages and a sleep score, the SPO2 reading should be listed if you click on that particular days sleep tile, and scroll down below time spent in each stage of sleep.
Unless you have an older phone. My old S5 won't show the SPO2 graph, but my newer phones do. Every time the Versa detected over 3 hours of sleep.
05-02-2020 06:23
05-02-2020 06:23
05-02-2020 13:02
05-02-2020 13:02
05-02-2020 14:10
05-02-2020 14:10
I checked the Fitbit.com dashboard and didn't see it there. My Galaxy S5 no longer gets fitbit app updates. Does yours? It looks like chat support is available. Maybe see what they say? You might need a newer phone to use that feature, but check with support? Premium probably wouldn't help either if your phone isn't updating the app.
05-09-2020 11:42
05-09-2020 11:42
Are we unable to see this in the online www.fitbit.com dashboard?
We can only see it in the app?
05-09-2020 12:20
05-09-2020 12:20
I couldn't find it. Don't know if you'll get an official response here.
05-09-2020 19:15
05-09-2020 19:15
05-25-2020 13:56
05-25-2020 13:56
@MrTimothyIrvine wrote:Are we unable to see this in the online www.fitbit.com dashboard?
The EOV graph in on the app only. It isn't on the web dashboard.
For other users with questions, the graph is on the same page where you see your sleep stages. Scroll to the bottom. If you are a premium member, the EOV graph is on the Restoration page.
@RLZ777 Are you seeing your graph? The EOV is available on the Ionic/Versa family/Charge 3/Charge 4. Are you using one of these? Sometimes users post in the incorrect device forum.
Laurie | Maryland
11-28-2020 08:33
11-28-2020 08:33
Download the SPO2 clockface for the Versa. And it will show on the watch in the morning after an hour or so. Also if you have Premium it will be stored under a section called Health Metrics.
02-08-2022 12:50
02-08-2022 12:50
How do I download it? My apo says the clockface isn't compatible with the OS on my Fitbit versa 2.
02-08-2022 18:27
02-08-2022 18:27
@NAOMIANNE21 How long have you had it? If it's brand new, you have to wait a couple days for a firmware update notification in the app.
