07-08-2020
16:59
12:01
DavideFitbit
07-08-2020
16:59
12:01
DavideFitbit
My Versa 2 screen is falling out. I was going to put it on the charger today & when I looked at it before taking it off I realized it was half out. It Hasn’t fallen all the way out yet and still seems to be working. I was thinking of getting a case to hold it together. I’m just worried about it eventually not working or getting water damage due to not being sealed together. Someone please help
Moderator edit: format
07-09-2020 00:21
07-09-2020 00:21
Hi, and welcome to the Community!
I've seen quite a few posts from people reporting this issue and it seems that it's not repairable. I would suggest contacting customer support. They can check your warranty status and advise on your options. You can get them via contact.fitbit.com
07-09-2020 12:00
07-09-2020 12:00
Hello @thatgirlmora, welcome to the Fitbit Community forums.
Thank you for sharing that you've been having trouble with your Versa 2 screen falling out.
I've gone ahead and sent your information to the Customer Support team for further assistance with this, so you should be getting a reply soon. Keep an eye on your inbox.
Let me know about te outcome.
07-10-2020 16:37
07-10-2020 16:37
Thank you so much!
07-11-2020 14:01
07-11-2020 14:01
07-14-2020 05:03
07-14-2020 05:03
They are sending me a replacement!!! Thanks for the help!
07-28-2020 06:56
07-28-2020 06:56
That's great news, thank you for the update @thatgirlmora! 😎
