04-17-2018
13:45
10:15
MarcoGFitbit
04-17-2018
13:45
10:15
MarcoGFitbit
I have a few issues with the screen
1. Turning the wrist does not always wake it, i usually resort to pressing a button. Is there a way to adjust the sensitivity?
2. Touching the screen does not always wake it. I usually have to press a button
3. Notifications do not wake it. As the above dont work i have to press the button - can this be a setting to wake please...
4. The clock face cant stay on all the time, it would be great to add an option to auto dim it and remain on. I know other ffaces are available but they suck, this bring me to my next point
5. Its really hard to find a clock face that is always on without installing it - this should be more visible in the app store (sorry i know not technically related to screen)
04-22-2019 07:31
04-22-2019 07:31
I turned the option to manual because I'm so tired of turning my wrist and hoping the screen to wake up (auto).
Even on manual setting, I need to tap several times the screen to turn it on.
My Versa is bought 15th Apr 2019.
What is going on with Fitbit? This is veeeeery annoying. I can not recommend this product to anyone.
04-22-2019 08:05
04-22-2019 08:05
Try putting onQuick View in your fitbit application on you phone
Best Answer04-22-2019 08:10
04-22-2019 08:10
I do have it "on"...... .it is not the solution. .. Sad 😥
Best Answer04-22-2019 08:52
04-22-2019 08:52
Best Answer04-22-2019 17:07
04-22-2019 17:07
Best Answer06-28-2019 03:56
06-28-2019 03:56
Try changing the setting of Wrist Placement to non dominant. I find that increases the wake up sensitivity level.
Best Answer06-28-2019 06:10
06-28-2019 06:10
Sounds like an idea worth trying to improve the responsiveness. Thanks.
Best Answer08-20-2019 21:18
08-20-2019 21:18
I’ve always had mine on non-dominant. I’ve done all suggested fixes and I’m still experiencing this issue 😞
Best Answer09-16-2019 14:07
09-16-2019 14:07
Mine would annoy me before, as every time I turned a page it lit up. Now it never lights up when I turn my wrist and I usually have to push the left button. Also, I have tried everything, but my Fitbit Versa still won't connect with my Iphone XR, while it worked fine with my 6.
Best Answer09-08-2020 07:35 - edited 09-08-2020 07:36
My watch updated this morning but now I can’t adjust my brightness, wake mode or do not disturb. Non responsive. I wouldn’t care but it’s to dim to see. Please advise. Dave
dbcypress@comcast.net
