04-19-2018
20:53
04:48
RobertoME
04-19-2018
20:53
04:48
RobertoME
I am still using charge HR. The listed function of versa is appealing. However, I read from the forum that the basic function like Heart rate tracking, sleep stage detection are comment to be not working. I wonder shall I buy it?
Moderator Edit: Updated Subject For Clarity.
Best AnswerI wouldn't. If anything get a used Ionic. The Versa has half the features the Ionic had and they don't even work properly. Battery life is at least 36hrs less. I'd continue but I won't be able to stop, very frustrated and upset with this garbage product Fitbit churned out to try and compete with other brands. All in all I would've been better off with MyFitnessPal and a Rugrats watch set to timer.
Yes, that’s the majority when looking at reviews because, and stay with me here I know this is a tough concept, companies want to sell products with good ratings. Try looking at CRITICAL reviews for the versa and you’ll see the problems are common and widespread, just not advertised the same way as a five star review.
And cool dude. I never said the Ionic had issues, quite the opposite, I recommended it. It has a longer battery life, more watch faces, more accurate data readings and is sturdier.
Im deferring the Versa because it’s an obvious cash grab for a half assed product. 2 minutes of research should bring you to this objective conclusion: the only thing the Versa has going for it when compared to other watches in this category, is the fact that it looks almost exactly like an Apple Watch which everyone objectively prefers over Fitbit’s designs. That and the dirt cheap price.
Best Answer@i2be I had a Charge HR before I got my Versa. I got my Versa two weeks ago and it's working great! Not trying to say that anyone who pre-ordered got a 'bad' Versa, but since it's been a couple of weeks, I think Fitbit has already sent out all their 'bad' ones and seen its problems and resolved them. When the issue with sleep, heart rate, and step counting came out, it never bothered me because I never had any of those issues. The battery life actually went above and beyond for me! It hit 5 days last charge and I check very often, I connect it to my phone for music a lot and for long periods of time, synced it at least twice a day, used Fitbit coach, Tennis, and exercise and it held! When I first got it, I was scared it would look big on my tiny wrist but it doesn't... Looks like Fitbit. The band changing process is a bit hard but switching from a Charge HR to a Versa, I really don't have experience with it. I say buy it and if it doesn't work, you can always return it.
Click Here to Vote for Fitbit Lock for Non-SE Versions!
Best AnswerWe can’t finish setting it up. It stops in middle and it keeps saying try again. Might return Friday since it won’t set up. You can email jsnyder5@comcast.net if someone can help. Best Buy Geek Squad could not set it up. They said too much Bluetooth in store or we need a. New phone.
Help!!!
Best AnswerCan you return it to Best Buy? My first versa died so I returned to back to Best Buy. Got my replacement and so far so good with the second one.
Best AnswerNo I didn’t but we don’t use a lot of electronics with Bluetooth. I did unpair it by mistake and it paired up again.
Best AnswerI bet and make the purchase through amazon. Based on my good experience in dealing with Fitbit in the past, I hope Fitbit is able to tackle it even there may be bug.
Best AnswerJust get the Apple Watch 1st or 2nd edition - there's literally zero reason to get a Versa when it's battery life is worse than an Apple Watch.
Best AnswerI bet that Fitbit is doing better at the sleeping stages monitoring. It also get SO2 sensor. Better resting HR monitoring. But I admitted that It is gambling
Best AnswerI honestly think that you should consider a different product.
I bought a Fitbit Versa on May 3, 2018. It worked fine until May 21st (less than 2 weeks).
On May 21st, the screen just turned totally black and stopped working. I tried restarting and it did nothing.
When I contacted customer support they would not take my word for it that I correctly performed a re-start and required me to send them a video, demonstrating the technique that I used in order to perform the re-start.
Once they decided that I wasn't completely incompetent, they emailed me a return label and told me that I had to drop if off at a Fex-Ex location. When they receive the broken Versa, they would send me a new one.
I mailed the fitbit using their FedEx label on May 23rd. They still have not received it. They say that according to the tracking number, they will receive it on May 31st.
Once they receive it, they will get around to sending me a new one after another 5-7 business days.
So, I paid over $200.00(with taxes) for a Fitbit that worked two weeks and will be without a working Fitbit for at least two weeks.
I seriously recommend that you take the advice that I should have listened to...and get yourself an apple watch.
Best AnswerIf you use an iPhone, I’d say be wary - my Versa (brand new as of last week) hasn’t even been able to get past the initial stages of setup until yesterday, and now the issue is that the device refuses to sync. However, my friend who has a functioning Versa loves it and all it’s capabilities. It’s also a cute watch.
