02-22-2025 05:17
02-22-2025 05:17
Yesterday I started having a fitbit issue. I saw last night there was a Fitbit update so I thought I would check in morning to see if problem fixed. It’s not fixed!!! I receive notifications that I achieved my first 5K. When I look at watch, it looks good? When I update app, it matches the watch. When I sync again, it starts generating all different step amounts and watch reflects all the strange amounts. I found if you sync over and over it eventually doesn’t change so I figured it was the correct steps. I had to do this all day and just now today. It let me know I had 5K but I knew I had about 3K shortly before so I knew not correct. I synced again and again and finally settled on about 4K for correct amount.
02-28-2025 04:35
02-28-2025 04:35
I've been using work around. I shut off Bluetooth most of the day and then I turn it back on and I use the sync area under the device. The sync automatically runs, twice. When you look at today the amount is going to be huge. If you go back to device and hit sync, when you look back at today, the amount matches whatever you originally saw on your watch before you did this process. If that original watch amount looked pretty accurate, it should match exactly what you now on the today amount including calories and miles.
The only thing that bums me out is that I also have been using my Health app on my iPhone and the amounts are at least two or 3000 less than my health app. The miles difference is really bad.
03-24-2025 10:42
03-24-2025 10:42
Is this now fixed for everyone. It seemed be working but has gone wrong again for me today.
Best Answer03-24-2025 12:24
03-24-2025 12:24
Best Answer03-24-2025 16:42
03-24-2025 16:42
Best Answer03-27-2025 13:58
03-27-2025 13:58
Hi everyone and welcome to the forums @julez_may.
Thanks for the steps that you tried and I appreciate the additional information you provided.
I'd like to share with you that this issue has been fixed. Your Fitbit device should be counting your steps correctly now.
Once again, I appreciate your patience.
