07-28-2022 04:07
07-28-2022 04:07
My Versa 2 just stopped working. Is there an internal battery to change?
07-28-2022 05:30
07-28-2022 05:30
Hi @Chef13 - unfortunately they are not repairable but first check the symptoms that are causing the problem.
Is the watch charged?
Sometimes just placing on the charger will restart it - make sure it does not get hot, in case it got water in it and is damaged inside which can cause it to stop.
Just pressing a button for 2 seconds may also start it.
Best Answer07-28-2022 07:57
07-28-2022 07:57
It was charged and just stopped. I’m going to try a new charger first.
Thank you for your help.
