04-25-2018 16:52
04-25-2018 16:52
Just seeing if anyone has some tips or tricks to changing the watch bands. I just took the classic band off and tried to put it back on and it was a painful experience especially on the end with the loop. How are others doing it?
i planned on getting a nicer band to wear during the work day then swap it out with the classic for a workout but it seems like a big nuisance to do every day.
06-22-2019 21:05
06-22-2019 21:05
Yes, this!!!!
07-02-2019 12:23
07-02-2019 12:23
I used to switch my
fitbit charge 2 bands almost daily but the versa is a nightmare! I just tried to change my band and the tiny pin broke off! Now it’s either break the band or the versa ☹️ Why did they change it and make
iy impossible to change?
07-02-2019 16:10
07-02-2019 16:10
@SunsetRunner wrote:I used to switch my
The first few times were a struggle and I broke many nails. Now I can switch bands much easier. The more you do it, the easier it becomes.
07-12-2019 07:07
07-12-2019 07:07
I too used to change out my previous bands almost daily to match what I was wearing for the day. I bought several new bands for my Versa with the expectation of doing the same thing, but they are a NIGHTMARE to change out. Do not try to change one out on the fly because it just won't happen. I've broken fingernails, had my thumbs actually bleed trying to get on a new band and finally gave up. Once I found one that I could get on, I just kept it on and just look at all my pretty unused bands and just shake my head.
07-12-2019 12:39
07-12-2019 12:39
I push the pin down with the retracted tip of a metal ballpoint pen. Still not all my bands will work. On one in particular the pins are obviously too short and just slide right out.
08-23-2019 19:08
08-23-2019 19:08
Okay, but I can’t get either the buckle or other side back in from my original versa. It’s too big. I just spent 20min with nothing but a broken nail to show for it.
11-26-2019 11:56
11-26-2019 11:56
show me how. this is getting frusrating
11-26-2019 13:13
11-26-2019 13:13
You have to have the band at almost a 90 degree angle to the Versa for it to pop in. Make sure you're holding the little knob down as far as it goes and you should hear a tiny click when it sets.
01-03-2020 13:50
01-03-2020 13:50
My buckle snapped off so I bought Fitbit brand bands. impossible to remove the pins so since I can't wear it I just tossed it...not worth the frustration
01-05-2020 10:45
01-05-2020 10:45
04-11-2020 19:28
04-11-2020 19:28
I actually found it easier to put the band on slightly backward, if you will. I lined up the end of the pin with the slider first. Then I used my thumbnail to press in the pin in the other end and pushed the strap into position and it snapped right into place. The little slider thing doesn’t move freely enough to snap nicely into place for some of them I think.
I’m posting in case it helps anyone, but also so when I have to do it again and I find this post, hopefully I’ll remember what I did!
06-01-2022 08:05
06-01-2022 08:05
You're a Goddess!
Worked like a hot-diggity!
Thanks very much 😀
06-01-2022 10:57
06-01-2022 10:57
