Best AnswerI've tried all the steps. we have deleted and recreated accounts. I got the Versa to pair but still couldn't add the device. So we started all over. Now I can't get the device to pair, its says I need incorrect PIN or passkey???? ive not seen this before......help
Best Answerhi! good day!
i have tried everything that you said, but still i cannot set up my versa 2!!!
i restore the factory settings... still doesn't work!!!
hope you could help me ASAP!!
thank you very much!!
Best AnswerI am having the same issue. I have tried all the tips, deleted & reinstalled the Fitbit app & have had to delete my versa & reinstall it on my phone each time I need to start again.
It also won't connect to WiFi even though my phone is connected so I'm trying to do this over Bluetooth. It's been 2 hours now & I'm on 20% & it has failed about 5 times which means I have to keep starting again
Best Answer07-08-2020 06:31 - last edited on 08-19-2020 19:41 by LiliyaFitbit
Hello,
I returned that one for a new one and it set up in like 5 minutes.
Good Luck!
Best AnswerI just recently had this same issue. My Fitbit stopped syncing so I un installed it from the app and it would not connect to reinstall it again.
I spoke via chat and phone with three different agents who all suggested the basics, that I restart my phone, watch, and Bluetooth. When those didn't work, the last agent said that my internal Bluetooth must have gone, and I needed to buy a new watch (with the offer of a discount code).
This didn't make sense to me as my phone was finding the watch, just not connecting.
I scrolled through my watch into Settings, then About, then chose Factory Reset. It connected immediately and is working and syncing again. Quite disappointed in the uselessness of the agents.
