04-27-2018
16:44
11:06
MarcoGFitbit
04-27-2018
16:44
11:06
MarcoGFitbit
I have been trying to install my Versa for 2 hours. It won't install on WIFI or bluetooth. Any ideas?
04-30-2018 11:07
04-30-2018 11:07
Hello @firegal, thanks for joining the Fitbit Community, it's great to have you on board. ![]()
Thanks for bringing this to my attention. If your Versa is still having trouble setting up, please try the following:
Now, before you begin the firmware update, make sure your watch is plugged into the charger and in range of your Wi-Fi network during the update. For best results, use your home or work Wi-Fi network. If you've never connected your watch to WiFi, see How do I connect my Fitbit watch to Wi-Fi?. If your Versa is having trouble updating with WiFi, please try the following:
If the update fails, restart your mobile device and try to update again. If you your Versa can't update over WiFi follow the on-screen instructions in the Fitbit app to update your watch over Bluetooth instead. Note that firmware updates over Bluetooth may take significantly longer to complete. If the Versa is having trouble updating through Bluetooth try the following:
I hope this can be helpful, give it a try and keep me posted in case you need anything else.
Best Answer06-02-2018 11:04
06-02-2018 11:04
I have the same problem. I followed all the steps but my phone just doesn't 'see' the verse fitbit. I bought it yesterday, I was able to set it up but after that it didn't sync anymore. Today I removed it to try and re-match it but that doesn't work, even though I did all the troubleshooting steps multiple times.
06-02-2018 11:20
06-02-2018 11:20
Best Answer10-21-2018 19:09
10-21-2018 19:09
I have been trying to sync my fitbit versa with my iphone6 plus all day. I tried everything suggested in this forum and was finally able to get it to sync when I restarted the watch by holding the left and bottom right buttons until the fitbit logo appeared. Thank you for your collective wisdom.
Best Answer10-23-2018 08:31
10-23-2018 08:31
Hello @Mshellen, thanks for joining the Fitbit Community, it's great to have you on board. ![]()
I appreciate your participation in the Forums and for letting us know that after restarting your device, it was able to sync, I'm very glad!
In case you have some spare time, I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
Best Answer05-09-2019 16:37
05-09-2019 16:37
I was a bit luckier and got it to work in about an hour. Every new fitbit device I have had has the same problem -- useless when trying to set up over bluetooth. A complete reinstall of the app on my phone worked, but why is that necessary? My Charge 3 had many problems trying to connect over bluetooth even once it was set-up, and I'm fearing the same with the Versa. The fitbits are a nice idea, but the devices in practice seem endlessly buggy, and I am close to abandoning using them.
05-11-2019 10:50
05-11-2019 10:50
@kmcgerty Welcome to our Fitbit Community! I'm glad to hear that you managed to get your Fitbit set up. Thank you for posting the update here.
I totally understand your frustrating and your feedback is greatly appreciated since this issue helps us to keep improving.
Don't hesitate to get back if you have any questions! ![]()
05-13-2019 14:57
05-13-2019 14:57
I have tried the online help and customer service. It all leads me to the same problem... the update download only loads to 5% then just stalls. I’ve tried every combination of on-off with devices and Bluetooth and same results.
Were any of you successful? I’m about ready to return it.
Best Answer05-13-2019 15:03
05-13-2019 15:03
05-13-2019 17:33
05-13-2019 17:33
Best Answer05-27-2019 09:35 - last edited on 03-09-2020 16:22 by LiliyaFitbit
Im working this today after brief failures during the last week. I got the fitbit versa because my old fitbit seemed simpler than my apple watch to track what I want to track most. So far no success.
Best Answer06-02-2019 14:17
06-02-2019 14:17
@firegal wrote:I have been trying to install my Versa for 2 hours. It won't install on WIFI or bluetooth. Any ideas?
Best Answer06-02-2019 17:35
06-02-2019 17:35
Best Answer07-08-2019 13:02
07-08-2019 13:02
I have just Got a VERSA in a gift, but i can’t set it up. I have Got it in the fitbit app, but i can’t Update the rest - software and i can’t use it!
I have follow all fine hints and now after 3 hours i need to return it or have some help!
I have fine network, so it is not the problems.
Best Answer07-09-2019 08:48
07-09-2019 08:48
Best Answer09-23-2019 10:19
09-23-2019 10:19
I've done this about 10-11 times. I've even deleted my account and created another one and it still will not work. About ready to throw it in the trash. Everything was working perfectly fine and it just all of a sudden stopped.
09-23-2019 10:57
09-23-2019 10:57
Best Answer12-25-2019 17:07
12-25-2019 17:07
Where do I find the help line number?
Best Answer12-25-2019 18:21
12-25-2019 18:21
