10-29-2019 10:26 - last edited on 10-30-2019 12:20 by LiliyaFitbit
I am unable to unlock versa, i had unsynced my versa trying to fix problem, now if it finds my versa, i can not put in the code because it says to unlock by phone...it can't because I, like a goofball unsynced it
01-05-2020 12:28
01-05-2020 12:28
Hi! I am having the same problem. The factory reset does not seem to work. I have tried and so has my husband. I keep getting the "unlock with phone" message but nothing is helping. Please help!
Best Answer01-05-2020 13:55
01-05-2020 13:55
Best Answer01-08-2020 05:20
01-08-2020 05:20
Best Answer02-24-2020 08:31
02-24-2020 08:31
Hi, Good day! I have similar issue with my Versa 2. I removed the device as it wasn't syncing but whenever I am trying to set up again, its asking me unlock the device thru phone. Any immediate help would be appreciated!
Best Answer06-16-2020 11:31
06-16-2020 11:31
I have the same problem. I removed the device and then it doesn’t work. And I can’t pair it anymore. Can someone escalate this?
Best Answer07-05-2020 07:39
07-05-2020 07:39
I did the exact same thing as the person who posted this after my 4yo daughter locked my Fitbit while it was on charge. This solution has not worked for me. I've tried it three times and every time it comes back to my Fitbit screen with my Fitbit bitmoji snoozing, which is what I should be doing!
Best Answer08-13-2020 10:51
08-13-2020 10:51
Hi,
I have the same problem, I did all the steps as you described but after the logo appears and there is the vibration then the unlock with phone message appears again
can you help ?
Thanks
Best Answer08-13-2020 11:11
08-13-2020 11:11
